return values of device driver routines
hwulf at et-inf.fho-emden.de hwulf at et-inf.fho-emden.de
Fri Jan 4 21:55:12 UTC 2008
Hi there,
how do the return values work in the RTEMS device driver routines
(open, close, read, write, ioctl)?
When I wanted to return the value (-1), do I have to execute "return
(-1);" or do I have to set a appropriate variable of the argument
structures (rtems_libio_open_close_args_t, rtems_libio_rw_args_t,
rtems_libio_ioctl_args_t)?
Thank you very much and kind regards,
  Hank
