netdemo problem
朱旭峰 fall4ufeng at gmail.com
Sun Jan 6 08:46:37 UTC 2008
Hello:
         I met some problems when I debug the netdemo.exe.
         The information is:
         Can't set rhine_eth1 address: Not owner
         Can't set default route: Network is unreachable
        And my networkconfig.h is :
static struct rtems_bsdnet_ifconfig netdriver_config = {
 "rhine_eth1",  /* name */
 rtems_rhine_driver_attach, /* attach function */
 NULL,    /* No more interfaces */
 "192.168.0.2",   /* IP address */
 "255.255.255.0",  /* IP net mask */
 NULL,                           /* Driver supplies hardware address */
 0    /* Use default driver parameters */
 * Network configuration
struct rtems_bsdnet_config rtems_bsdnet_config = {
 &netdriver_config,
 NULL,
 100,   /* Default network task priority */
 128*1024,  /* Default mbuf capacity */
 256*1024,  /* Default mbuf cluster capacity */
 "rtems_host",  /* Host name */
 "localnet",  /* Domain name */
 "192.168.0.1",  /* Gateway */
 "192.168.0.1",  /* Log host */
 {"192.168.0.1" }, /* Name server(s) */
 {"192.168.0.1" }, /* NTP server(s) */
            any help will be appreciated .
URL: <http://lists.rtems.org/pipermail/users/attachments/20080106/412c97ed/attachment.html>
