RTEMS_INVALID_NUMBER in rtems_io_register_driver
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jan 11 17:03:31 UTC 2008
Gatti André wrote:
> We get the error RTEMS_INVALID_NUMBER when trying to register an IO
> driver with the call to rtems_io_register_driver (in the function
> initDriver()).
How did you configure the system? You should have specified
CONFIGURE_MAXIMUM_DRIVERS to be greater than the
number of statically specified drivers.
> The function initDriver() is call in the bspStart.c file.
> The condition that cause the problem inside rtems_io_register_driver() is
> if ( major >= _IO_Number_of_drivers )
> return RTEMS_INVALID_NUMBER;
> Example:
> static rtems_status_code rtems_io_initialize(rtems_device_major_number
> major, rtems_device_minor_number minor, void * argument);
> static rtems_status_code rtems_io_open(rtems_device_major_number
> static rtems_status_code rtems_io_close(rtems_device_major_number
> static rtems_status_code rtems_io_read(rtems_device_major_number
> static rtems_status_code rtems_io_write(rtems_device_major_number
> static rtems_status_code rtems_io_control(rtems_device_major_number
> rtems_driver_address_table driver_table = {
> rtems_io_initialize,
> rtems_io_open,
> rtems_io_close,
> rtems_io_read,
> rtems_io_write,
> rtems_io_control,
> void init(){
> rtems_status_code r;
> rtems_device_major_number registered_major;
> if ((r = rtems_io_register_driver(0, &driver_table,
> ®istered_major)) == RTEMS_SUCCESSFUL) {
> printk("Driver successfully registered, major: %d\n",
> registered_major);
> } else {
> switch(r) {
> case RTEMS_TOO_MANY:
> printk("rtems_io_register_driver failed: RTEMS_TOO_MANY
> (%d)\n", registered_major); break;
> case RTEMS_INVALID_NUMBER:
> RTEMS_INVALID_NUMBER (%d)\n", registered_major); break;
> case RTEMS_RESOURCE_IN_USE:
> RTEMS_RESOURCE_IN_USE (%d)\n", registered_major); break;
> default:
> printk("rtems_io_register_driver failed (%d)\n",
> registered_major);
> return;
> rtems_status_code rtems_io_initialize(rtems_device_major_number major,
> rtems_device_minor_number minor, void * argument){
> if(rtems_io_register_name("/dev/iodriver", registered_major, 0) ==
> RTEMS_SUCCESSFUL){
> return RTEMS_SUCCESSFUL;
> return RTEMS_INTERNAL_ERROR;
> rtems_status_code rtems_io_open(rtems_device_major_number major,
> printk("Open.\n");
> rtems_status_code rtems_io_close(rtems_device_major_number major,
> printk("Close.\n");
> rtems_status_code rtems_io_read(rtems_device_major_number major,
> printk("Read.\n");
> rtems_status_code rtems_io_write(rtems_device_major_number major,
> printk("Write.\n");
> rtems_status_code rtems_io_control(rtems_device_major_number major,
> printk("Control.\n");
> rtems-users mailing list
> rtems-users at rtems.com
