RTEMS_INVALID_NUMBER in rtems_io_register_driver
Fri Jan 11 17:18:29 UTC 2008
Gatti André wrote:
> We get the error RTEMS_INVALID_NUMBER when trying to register an IO
> driver with the call to rtems_io_register_driver (in the function
> initDriver()).
Has RTEMS even been initialized yet?   Are you in the function
 bsp_start?  If so, then it hasn't.
_IO_Number_of_drivers could be 0 if RTEMS isn't initialized.
> The function initDriver() is call in the bspStart.c file.
> The condition that cause the problem inside rtems_io_register_driver() is
>     if ( major >= _IO_Number_of_drivers )
>         return RTEMS_INVALID_NUMBER;
> Example:
> static rtems_status_code rtems_io_initialize(rtems_device_major_number
> major, rtems_device_minor_number minor, void * argument);
> static rtems_status_code rtems_io_open(rtems_device_major_number
> static rtems_status_code rtems_io_close(rtems_device_major_number
> static rtems_status_code rtems_io_read(rtems_device_major_number
> static rtems_status_code rtems_io_write(rtems_device_major_number
> static rtems_status_code rtems_io_control(rtems_device_major_number
> rtems_driver_address_table driver_table = {
>     rtems_io_initialize,
>     rtems_io_open,
>     rtems_io_close,
>     rtems_io_read,
>     rtems_io_write,
>     rtems_io_control,
> void init(){
>     rtems_status_code r;
>     rtems_device_major_number registered_major;
>    if ((r = rtems_io_register_driver(0, &driver_table,
> &registered_major)) == RTEMS_SUCCESSFUL) {
>         printk("Driver successfully registered, major: %d\n",
> registered_major);
>     } else {
>         switch(r) {
>         case RTEMS_TOO_MANY:
>             printk("rtems_io_register_driver failed: RTEMS_TOO_MANY
> (%d)\n", registered_major); break;
>         case RTEMS_INVALID_NUMBER:
> RTEMS_INVALID_NUMBER (%d)\n", registered_major); break;
>         case RTEMS_RESOURCE_IN_USE:
> RTEMS_RESOURCE_IN_USE (%d)\n", registered_major); break;
>         default:
>            printk("rtems_io_register_driver failed (%d)\n",
> registered_major);
>     return;
> rtems_status_code rtems_io_initialize(rtems_device_major_number major,
> rtems_device_minor_number minor, void * argument){
>     if(rtems_io_register_name("/dev/iodriver", registered_major, 0) ==
> RTEMS_SUCCESSFUL){
>         return RTEMS_SUCCESSFUL;
>     return RTEMS_INTERNAL_ERROR;
> rtems_status_code rtems_io_open(rtems_device_major_number major,
>     printk("Open.\n");
> rtems_status_code rtems_io_close(rtems_device_major_number major,
>     printk("Close.\n");
> rtems_status_code rtems_io_read(rtems_device_major_number major,
>     printk("Read.\n");
> rtems_status_code rtems_io_write(rtems_device_major_number major,
>     printk("Write.\n");
> rtems_status_code rtems_io_control(rtems_device_major_number major,
>     printk("Control.\n");
> rtems-users mailing list
> rtems-users at rtems.com
