RTEMS_INVALID_NUMBER in rtems_io_register_driver
Fri Jan 11 18:10:31 UTC 2008
Gatti André wrote:
> Actually, the initDriver() call is inside bsp_start(), so, as you
> said, RTEMS is not initialized. If this is the wrong place, where
> should this function call would be?
The point of dynamic registration is to do it after the system is fully
initialized
and to do it from a task.
In this case, I would either add it to the static driver table or add it
from
the first task.  Or you could add it in the BSP in either the pre-driver
or post-driver hook.
> I also tried declaring CONFIGURE_MAXIMUM_DRIVERS with a high number in
> my application, but with the same result (RTEMS_INVALID_NUMBER). But
> is this necessary if we are using dynamic registration
> (rtems_io_register_driver)?
No it is because RTEMS wasn't initialized yet and this had no effect yet.
The variable in question was zeroed out by the start.S zeroBSS loop and
hasn't been set to the configured number yet.
> Thanks,
> Joel Sherrill escribió:
>> Gatti André wrote:
>>> We get the error RTEMS_INVALID_NUMBER when trying to register an IO
>>> driver with the call to rtems_io_register_driver (in the function
>>> initDriver()).
>> Has RTEMS even been initialized yet?   Are you in the function
>> bsp_start?  If so, then it hasn't.
>> _IO_Number_of_drivers could be 0 if RTEMS isn't initialized.
>>> The function initDriver() is call in the bspStart.c file.
>>> The condition that cause the problem inside
>>> rtems_io_register_driver() is
>>>     if ( major >= _IO_Number_of_drivers )
>>>         return RTEMS_INVALID_NUMBER;
>>> Example:
>>> static rtems_status_code
>>> rtems_io_initialize(rtems_device_major_number major,
>>> rtems_device_minor_number minor, void * argument);
>>> static rtems_status_code rtems_io_open(rtems_device_major_number
>>> major, rtems_device_minor_number minor, void * argument);
>>> static rtems_status_code rtems_io_close(rtems_device_major_number
>>> static rtems_status_code rtems_io_read(rtems_device_major_number
>>> static rtems_status_code rtems_io_write(rtems_device_major_number
>>> static rtems_status_code rtems_io_control(rtems_device_major_number
>>> rtems_driver_address_table driver_table = {
>>>     rtems_io_initialize,
>>>     rtems_io_open,
>>>     rtems_io_close,
>>>     rtems_io_read,
>>>     rtems_io_write,
>>>     rtems_io_control,
>>> void init(){
>>>     rtems_status_code r;
>>>     rtems_device_major_number registered_major;
>>>    if ((r = rtems_io_register_driver(0, &driver_table,
>>> &registered_major)) == RTEMS_SUCCESSFUL) {
>>>         printk("Driver successfully registered, major: %d\n",
>>> registered_major);
>>>     } else {
>>>         switch(r) {
>>>         case RTEMS_TOO_MANY:
>>>             printk("rtems_io_register_driver failed: RTEMS_TOO_MANY
>>> (%d)\n", registered_major); break;
>>>         case RTEMS_INVALID_NUMBER:
>>> RTEMS_INVALID_NUMBER (%d)\n", registered_major); break;
>>>         case RTEMS_RESOURCE_IN_USE:
>>> RTEMS_RESOURCE_IN_USE (%d)\n", registered_major); break;
>>>         default:
>>>            printk("rtems_io_register_driver failed (%d)\n",
>>> registered_major);
>>>     return;
>>> rtems_status_code rtems_io_initialize(rtems_device_major_number
>>> major, rtems_device_minor_number minor, void * argument){
>>>     if(rtems_io_register_name("/dev/iodriver", registered_major, 0)
>>> == RTEMS_SUCCESSFUL){
>>>                return RTEMS_SUCCESSFUL;
>>>     return RTEMS_INTERNAL_ERROR;
>>> rtems_status_code rtems_io_open(rtems_device_major_number major,
>>>     printk("Open.\n");
>>> rtems_status_code rtems_io_close(rtems_device_major_number major,
>>>     printk("Close.\n");
>>> rtems_status_code rtems_io_read(rtems_device_major_number major,
>>>     printk("Read.\n");
>>> rtems_status_code rtems_io_write(rtems_device_major_number major,
>>>     printk("Write.\n");
>>> rtems_status_code rtems_io_control(rtems_device_major_number major,
>>>     printk("Control.\n");
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
