Hello world with leon2 problem
Arquer Stephane
stephane.arquer at c-s.cnes.fr
Tue Jan 22 15:46:58 UTC 2008
Hi,
I'm trying to compile a simple hello_world.c example with rtems v4.7.1
using the BSP leon2.
The same example compiled with rtems v4.6.6 runs on the target, but when
I compile it with rtems v4.7.1 an error occurs just after the "go".
I don't have grmon for the moment, so I don't know anything else about
the error.
Is there something else to configure regarding the previous rtems
version ?
Thanks ahead for any help.
Sa.
I use the following linkcmds file:
/* linkcmds
* linkcmds,v 1.4 2003/01/20 20:19:35 joel Exp
OUTPUT_ARCH(sparc)
__DYNAMIC = 0;
* The memory map looks like this:
* +--------------------+ <- low memory
* | .text |
* | etext |
* | ctor list | the ctor and dtor lists are for
* | dtor list | C++ support
* | _endtext |
* | .data | initialized data goes here
* | _sdata |
* | _edata |
* | .bss |
* | __bss_start | start of bss, cleared by crt0
* | _end | start of heap, used by sbrk()
* | heap space |
* | _ENDHEAP |
* | stack space |
* | __stack | top of stack
* +--------------------+ <- high memory
* User modifiable values:
* _CLOCK_SPEED in Mhz (used to program the
counter/timers)
* _PROM_SIZE size of PROM (permissible values are 128K,
256K,
* 512K, 1M, 2M, 4M, 8M and 16M)
* _RAM_SIZE size of RAM (permissible values are 256K,
512K,
* 1M, 2M, 4M, 8M, 16M, and 32M)
/* Default values, can be overridden */
/*_CLOCK_SPEED = 8;*/ /* carte inicore */
/*_CLOCK_SPEED = 5;*/ /* carte bertin */
_CLOCK_SPEED = 20;
_PROM_SIZE = 4M;
_RAM_SIZE = 2M;
/* _RAM_START = 0x60000000;*/
/*_RAM_START = 0x40020000;*/
_RAM_START = 0x40060000;
_RAM_END = _RAM_START + _RAM_SIZE;
_PROM_START = 0x00000000;
_PROM_END = _PROM_START + _PROM_SIZE;
* Alternate names without leading _.
PROM_START = _PROM_START;
PROM_SIZE = _PROM_SIZE;
PROM_END = _PROM_END;
RAM_START = _RAM_START;
RAM_SIZE = _RAM_SIZE;
RAM_END = _RAM_END;
* Base address of the on-CPU peripherals
_LEON_REG = 0x80000000;
/* these are the maximum values */
MEMORY
rom : ORIGIN = 0x00000000, LENGTH = 256M
/* ram : ORIGIN = 0x60000000, LENGTH = 1024M */
ram : ORIGIN = 0x40060000, LENGTH = 1024M
* stick everything in ram (of course)
SECTIONS
.text :
CREATE_OBJECT_SYMBOLS
text_start = .;
_text_start = .;
*(.text)
. = ALIGN (16);
* Special FreeBSD sysctl sections.
. = ALIGN (16);
__start_set_sysctl_set = .;
*(set_sysctl_*);
__stop_set_sysctl_set = ABSOLUTE(.);
*(set_domain_*);
*(set_pseudo_*);
*(.eh_frame)
. = ALIGN (16);
*(.gnu.linkonce.t*)
* C++ constructors
__CTOR_LIST__ = .;
LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
*(.ctors)
LONG(0)
__CTOR_END__ = .;
__DTOR_LIST__ = .;
LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
*(.dtors)
LONG(0)
__DTOR_END__ = .;
_rodata_start = . ;
*(.rodata*)
*(.gnu.linkonce.r*)
_erodata = ALIGN( 0x10 ) ;
etext = ALIGN(0x10);
_etext = .;
*(.init)
*(.fini)
*(.lit)
*(.shdata)
. = ALIGN (16);
_endtext = .;
} > ram
.dynamic : { *(.dynamic) } >ram
.jcr : { *(.jcr) } >ram
.got : { *(.got) } >ram
.plt : { *(.plt) } >ram
.hash : { *(.hash) } >ram
.dynrel : { *(.dynrel) } >ram
.dynsym : { *(.dynsym) } >ram
.dynstr : { *(.dynstr) } >ram
.data :
data_start = .;
_data_start = .;
_sdata = . ;
*(.data)
*(.gnu.linkonce.d*)
*(.gcc_except_table)
. = ALIGN(0x10);
edata = .;
_edata = .;
} > ram
.shbss :
*(.shbss)
} > ram
.bss :
__bss_start = ALIGN(0x8);
_bss_start = .;
bss_start = .;
*(.bss)
*(COMMON)
end = .;
_end = ALIGN(0x8);
__end = ALIGN(0x8);
} > ram
.stab . (NOLOAD) :
[ .stab ]
.stabstr . (NOLOAD) :
[ .stabstr ]
