socket io problem
CWolfe at motioncontrol.org
Tue Jan 29 20:48:59 UTC 2008
Hi all,
I'm having a problem using sockets, and I hope someone might know what i'm doing wrong.
In a previous email, I mentioned i'm trying to create a telnet server which directly manipulates
the rs-232 buffers (as opposed to using ptys which wouldn't be compatible with our
application.) I can read and write to and from the socket, but only in a blocking way, which
doesn't fit our needs. I've tried to register handlers for the sopcket, but they never get called. I
have modeled my socket initialization on the telnetd.c and also GoAhead's initialization code.
Could someone possibly explain how i can set up a telnet socket which is non-blocking at
minimum, but even better, one that actually calls the handlers on reception/transmission?
I assume it's something small that I'm missing, but nothing i've tried has worked in triggering
execution of the socketHandler function. Thank you for your time.
Regards,
Christopher Wolfe
Motion Control Systems, Inc.
