Another Ethernet problem for Thomas :) Cont.
Wed Jan 30 13:55:35 UTC 2008
Leon Pollak wrote:
> One more detail discovered only now:
> If I put the delay of 7s (!!) before I start to open the UDP socket, the first
> packet always arrives!
> The less time delay is insufficient.
A numerologist would tell you that 7 is a perfect number and
that it must be a sign. :-D
Are you on a cross-over cable, private subnet, etc?
Can you see the packet on the wire with Ethereal/WireShark/tcpdump?
> What's this, gurus!
> Leon
> rtems-users mailing list
> rtems-users at rtems.com
