Register an IO driver
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jan 4 16:50:23 UTC 2008
Gatti André wrote:
> We are making a BSP and want to register an IO driver but we are not
> sure where tu put the call to the function rtems_io_register_driver.
> We think that the correct place should be inside rtems_io_initialize,
> but the problem is that the call to rtems_io_initialize already
> includes the major and minor number as parameters.
> rtems_status_code rtems_io_initialize(rtems_device_major_number major,
> rtems_device_minor_number minor, void * argument);
> So should be a place before rtems_io_initialize, it would be great if
> someone can tell us how to do it.
It is called automatically during RTEMS initialization.
> Apart from that when we call the function rtems_io_register_driver(0,
> &driver_table, ®istered_major) we get the error RTEMS_TOO_MANY.
> This is because there is not enought space in the device driver table,
> but we don't want to modified the constant CONFIGURE_MAXIMUM_DRIVERS
> in confdefs.h, is it automatically incremented?
In 4.7 and older, you had to do your own driver table with the same name.
confdefs.h should pick up the name and size automatically.
4.8 and newer have CONFIGURE_APPLICATION_EXTRA_DRIVERS which lets you
add to the table generated by confdefs.h easily.
CONFIGURE_NUMBER_OF_DRIVERS is the number of statically configured
drivers.
CONFIGURE_MAXIMUM_DRIVERS is the maximum number of driver and
includes those dynamically registered.
> Please, can anyone tell us which is wrong here:
> Example of our driver:
> static rtems_status_code rtems_io_initialize(rtems_device_major_number
> major, rtems_device_minor_number minor, void * argument);
> static rtems_status_code rtems_io_open(rtems_device_major_number
> static rtems_status_code rtems_io_close(rtems_device_major_number
> static rtems_status_code rtems_io_read(rtems_device_major_number
> static rtems_status_code rtems_io_write(rtems_device_major_number
> static rtems_status_code rtems_io_control(rtems_device_major_number
> rtems_driver_address_table driver_table = {
> rtems_io_open,
> rtems_io_close,
> rtems_io_read,
> rtems_io_write,
> rtems_io_control,
> rtems_device_minor_number minor, void * argument){
> rtems_device_major_number registered_major;
> if(rtems_io_register_driver(0, driver_table, ®istered_major) ==
> RTEMS_SUCCESSFUL){
> rtems_io_register_name("iodriver", registered_major, 0);
> return RTEMS_SUCCESSFUL;
> return RTEMS_INVALID_NUMBER;
> rtems_status_code rtems_io_open(rtems_device_major_number major,
> printk("Open.\n");
> rtems_status_code rtems_io_close(rtems_device_major_number major,
> printk("Close.\n");
> rtems_status_code rtems_io_read(rtems_device_major_number major,
> printk("Read.\n");
> rtems_status_code rtems_io_write(rtems_device_major_number major,
> printk("Write.\n");
> rtems_status_code rtems_io_control(rtems_device_major_number major,
> printk("Control.\n");
> rtems-users mailing list
> rtems-users at rtems.com
