netdemo problem
Mon Jan 7 14:36:22 UTC 2008
What RTEMS version is this?  Is this on the CVS head by
any chance?
--joel
朱旭峰 wrote:
> Hello:
>          I met some problems when I debug the netdemo.exe.
>          The information is:
>          Can't set rhine_eth1 address: Not owner
>          Can't set default route: Network is unreachable
>         And my networkconfig.h is :
> static struct rtems_bsdnet_ifconfig netdriver_config = {
>  "rhine_eth1",  /* name */
>  rtems_rhine_driver_attach, /* attach function */
>  NULL,    /* No more interfaces */
>  "192.168.0.2 <http://192.168.0.2>",   /* IP address */
>  "255.255.255.0 <http://255.255.255.0>",  /* IP net mask */
>  NULL,                           /* Driver supplies hardware address */
>  0    /* Use default driver parameters */
>  * Network configuration
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>  &netdriver_config,
>  NULL,
>  100,   /* Default network task priority */
>  128*1024,  /* Default mbuf capacity */
>  256*1024,  /* Default mbuf cluster capacity */
>  "rtems_host",  /* Host name */
>  "localnet",  /* Domain name */
>  "192.168.0.1 <http://192.168.0.1>",  /* Gateway */
>  "192.168.0.1 <http://192.168.0.1>",  /* Log host */
>  {"192.168.0.1 <http://192.168.0.1>" }, /* Name server(s) */
>  {"192.168.0.1 <http://192.168.0.1>" }, /* NTP server(s) */
>             any help will be appreciated .
> rtems-users mailing list
> rtems-users at rtems.com
