Help with MinGW and 4.8 release candidate
Chris Johns
chrisj at rtems.org
Tue Jan 8 23:38:01 UTC 2008
Richard Greer wrote:
> I am using 4.8-16 of the RTEMS MinGW tools. I was wondering if there is
> an update for those tools that I might be missing, as I have a RedHat
> box that can build it just fine (it is a long story why I also want to
> build RTEMS using MinGW that I will not bore you with), but I believe it
> has more recent copies of the build tools.
> It is most likely the case that I have missed something obvious, since I
> do not play with MinGW much at all. Any help would be appreciated.
I need to create a new set of tools. Something must have moved between newlib
and RTEMS. I will send a post when I have the tools built.
Regards
