Some thoughts about the flash device driver and the flashdisk block driver
Ian Caddy
ianc at goanna.iinet.net.au
Thu Jan 24 23:12:06 UTC 2008
Hi Astrid,
Astrid Hanssen wrote:
> Its the Coldfire MCF5208 evaluation board, which contains an AMD
> AM29BDD160G 16/32-bit flash device.
> Although I already started writing my own flash chip driver, now
> I like to switch over to the chip driver format defined by
> flashdisk.h and the example that can be found in libchip/flash.
> After the flash driver will be thoroughly tested, I feel like
> submitting it to libchip/flash.
> However, not the whole area of the flash chip shall be available
> to the libblock flashdisk block driver. The device will also have
> to contain the RTEMS software itself as well as some type of an
> optimized flash parameter storage system.
> The latter may also use the flash device driver, but not the
One thing to be aware of is that most NOR type flash chips do not allow
you to read from them while writing to them. This would mean that you
can't run RTEMS from the flash while programming another area of the
same flash chip.
There are normally two solutions to this problem, copy everything into
RAM and run from there, allowing full access to the flash, or have a
separate flash chip for your file system.
Hope this helps.
regards,
Ian Caddy
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
