Simple udp echo problem
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jan 28 16:30:56 UTC 2008
Leon Pollak wrote:
> On Monday, 28 בJanuary 2008, Thomas Doerfler wrote:
>> Hi Leon,
>> this is just a bad guess:
>> is it possible that your networking driver does not PAD short transmit
>> frames to the minimum length of 64 bytes (total packet length)? Some
>> network controllers (including the *QUICC* family from Freescale) allows
>> to switch this padding off (or to define the minimum transmit packet
>> length) and this would make the device send short packets. Most switches
>> (and receivers) would ignore these packets.
>> wkr,
>> Thomas.
> Thomas,
> You hit the bull in the eye!!!
Nice one Thomas. :-D
Is this a driver in the RTEMS source tree? If so, we need
a patch.
> I was looking all around the code for 2 days already!
> 1001 of thanks.
> Leon.
> rtems-users mailing list
> rtems-users at rtems.com
