Problem building gcc 4.3.1 cross-compiler with ada
Dirk Heinrichs
dirk.heinrichs at online.de
Mon Jul 14 16:12:43 UTC 2008
Am Montag, 14. Juli 2008 schrieb Joel Sherrill:
> Dirk Heinrichs wrote:
> > Am Sonntag, 13. Juli 2008 schrieb Joel Sherrill:
> >> How about the attached Ada specific patch?
> > Unfortunatley, it didn't change anything.
> Weird. I have built powerpc, mips, i386, and sparc
> and run the ACATS on this for 4.3.1.
> When you look at ada/Makefile.in and search for rtems
> as a target pair do you see numaux in the list? It shouldn't
> be there.
No, it's not there for rtems (but for other targets).
> What version is your native Ada compiler? You have to have
> the same native Ada as the cross you are building.
Yes, it's also 4.3.1, built from the same source dir. And I've also built a
C-only cross compiler before, as per wiki instructions.
> This is my configure line:
> ../${GCCSRCDIR}/configure \
> --enable-threads=rtems --with-gnu-as --disable-multilib \
> --with-gnu-ld --with-newlib --verbose --with-system-zlib --disable-nls
> \ --enable-version-specific-runtime-libs \
> --enable-languages=c,ada --target=$TARGET --prefix=$INSTALL
Mine looks nearly the same:
../gcc-4.3.1/configure \
--with-gnu-ld --with-newlib --verbose --with-system-zlib --disable-nls \
--enable-languages=c,c++,ada --target=i386-rtems --prefix=/opt \
--program-prefix=i386-rtems-
Bye...
Dirk
Type: application/pgp-signature
Desc: This is a digitally signed message part.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080714/888841a9/attachment.bin>
