autoconf 2.62
Till Straumann
strauman at slac.stanford.edu
Tue Jul 8 06:34:11 UTC 2008
Ralf Corsepius wrote:
> On Mon, 2008-07-07 at 15:05 -0700, Till Straumann wrote:
>> Ralf.
>> I saw this thread
>> http://lists.gnu.org/archive/html/bug-autoconf/2008-04/msg00028.html
>> and apparently you now use autoconf 2.62 on the CVS head (what
>> is to become 4.9).
> Correct.
> I could not avoid to upgrade to 2.62, because RTEMS's configuration is
> victim of a couple of incompatibilities between autoconf-2.62 and 2.61.
>> Unfortunately, our site uses RHEL4 and I'm stuck.
> Also correct. Upstream autoconf has made a couple of unfortunate
> decisions, which render autoconf-2.62 non-applicable on
> ultra-conservative distros such as RHEL4.
> A corresponding request to upgrade RHEL4's (broken and defective) gm4, I
> filed at RedHat in April
> (https://bugzilla.redhat.com/show_bug.cgi?id=443958)
> so far has remained without any results.
> It might have escaped you, but this issue already had forced me to
> abandon RTEMS-4.9 toolchain support for RHEL4 some time ago
> (in April or May).
>> Do I now have to build + install gm4?
> That's one option.
The only one. Luckily it's not much more than just another
nuisance.
The other suggestion of abandoning RHEL4 is not an option.
We're a bigger organization and it is way beyond my control
what distro is installed on our workstations -- I'm sure this
applies to other sites, too.
Whether you (or myself) like it or not, RHEL is a major, widely
used distro and it doesn't help RTEMS to 'abandon support'
for it, IMHO. I say this having no personal interest since I
always build my toolchains myself (the RPM install location
doesnt' fit our filesystem layout here anyways).
FWIW
T.
> The best alternative would be RH to upgrade RHEL4's gm4. Yet another
> alternative would be us to ship a modern gm4 to replace RHEL4's gm4.
> Yet another alternative would be users to switch the distro :/
> As I see it: RHEL4 is a server-OS, which gradually is showing its age
> and meanwhile has evolved into "too outdated"/"non-suitable" for
> forward-looking development purposes.
>> Any chance to remain with autoconf 2.61 for
>> the 4.9 release?
> Hardly possible.
> We have to choose between 2 evils: Stick with antiquated versions of SW
> with known defects or abandon supporting antiquated/ultra-conservative
> host-OSes with known defects.
> Ralf
