Error from ampolish3
Neil Mayes N.Mayes at sstl.co.uk
Mon Jun 2 15:58:32 UTC 2008
> -----Original Message-----
> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> Sent: 02 June 2008 16:54
> To: Neil Mayes
> Cc: rtems-users at rtems.org
> Subject: RE: Error from ampolish3
> On Mon, 2008-06-02 at 15:48 +0100, Neil Mayes wrote:
> > Hi,
> > I have (tried to!) added some device drivers to a BSP (ERC32) and
> > wanted to isolate the IO control to a HW API. So the
> application would
> > just need to include the header and all will be well. Once
> I realised
> > I needed to regenerate preinstall.am I used bootstrap -p however I
> > encountered the following error:
> > Can't do setuid (cannot exec sperl)
> Not from RTEMS. Nothing in RTEMS is using suid-perl.
> > Has anyone got an clue where the error is coming from?
> Seems to me as if you have a permission problem with your
> source tree or a problem with your perl installation.
I suspect the perl setup :(
> Ralf
Thanks Ralf
