Error from ampolish3
Neil Mayes N.Mayes at sstl.co.uk
Mon Jun 2 16:22:14 UTC 2008
My permissions:
  -rwxrwsr-x   1 nmayes nmayes   7766 May 21 11:21 ampolish3
> -rwxr-xr-x 1 joel users 7766 2007-01-08 02:38 ampolish3
Thanks,
Neil
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 02 June 2008 17:19
> To: Neil Mayes
> Cc: Ralf Corsepius; rtems-users at rtems.org
> Subject: Re: Error from ampolish3
> Neil Mayes wrote:
> > Sorry I should have supplied details:
> > i686-pc-linux RHEL4 & RTEMS4.8.0
> > Be gentle, linux newbie.
> Being gentle.  Just thought host might provide some details.
> I don't recall anyone ever reporting this particular error
> before.  But google is your friend.. just google on the error
> message and I found this:
> http://www.brandonchecketts.com/archives/fix-for-centos-cant-d
> o-setuid-cannot-exec-sperl
> Looks like you might need to load another RPM.
> If I am reading the messages correctly, this means something
> has an suid bit set which doesn't seem right for ampolish3.
> It doesn't have that bit set in my tree:
> $ ls -l ampolish3
> and I don't see the string uid in that script.  Ralf wrote
> that script so might have another thought but I am curious if
> your permissions match on ampolish3.
> --joel
> > Thanks,
> > Neil
> >> Sent: 02 June 2008 17:02
> >> To: Neil Mayes
> >> I'm sure you have told us before but what OS and version Neil?
> >>>> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> >>>> Sent: 02 June 2008 16:54
> >>>> To: Neil Mayes
> >>>> Cc: rtems-users at rtems.org
> >>>> Subject: RE: Error from ampolish3
> >>>> On Mon, 2008-06-02 at 15:48 +0100, Neil Mayes wrote:
> >>>>> Hi,
> >>>>> I have (tried to!) added some device drivers to a BSP
> (ERC32) and
> >>>>> wanted to isolate the IO control to a HW API. So the
> >>>> application would
> >>>>> just need to include the header and all will be well. Once
> >>>> I realised
> >>>>> I needed to regenerate preinstall.am I used bootstrap -p
> >> however I
> >>>>> encountered the following error:
> >>>>> Can't do setuid (cannot exec sperl)
> >>>> Not from RTEMS. Nothing in RTEMS is using suid-perl.
> >>>>> Has anyone got an clue where the error is coming from?
> >>>> Seems to me as if you have a permission problem with your
> >> source tree
> >>>> or a problem with your perl installation.
> >>> I suspect the perl setup :(
> >>>> Ralf
> >>> Thanks Ralf
> >>> _______________________________________________
> >>> rtems-users mailing list
> >>> rtems-users at rtems.com
> >>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> >> Joel Sherrill, Ph.D.             Director of Research & Development
> >> joel.sherrill at OARcorp.com        On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>    Support Available             (256) 722-9985
