Error from ampolish3
Mon Jun 2 16:24:08 UTC 2008
Neil Mayes wrote:
> My permissions:
>   -rwxrwsr-x   1 nmayes nmayes   7766 May 21 11:21 ampolish3
>> -rwxr-xr-x 1 joel users 7766 2007-01-08 02:38 ampolish3
That's not right. :-D
chmod 755 ampolish3
Or it might be time to move your changes carefully to
a fresh source tree.
> Thanks,
> Neil
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: 02 June 2008 17:19
>> To: Neil Mayes
>> Cc: Ralf Corsepius; rtems-users at rtems.org
>> Subject: Re: Error from ampolish3
>> Neil Mayes wrote:
>>> Sorry I should have supplied details:
>>> i686-pc-linux RHEL4 & RTEMS4.8.0
>>> Be gentle, linux newbie.
>> Being gentle.  Just thought host might provide some details.
>> I don't recall anyone ever reporting this particular error
>> before.  But google is your friend.. just google on the error
>> message and I found this:
>> http://www.brandonchecketts.com/archives/fix-for-centos-cant-d
>> o-setuid-cannot-exec-sperl
>> Looks like you might need to load another RPM.
>> If I am reading the messages correctly, this means something
>> has an suid bit set which doesn't seem right for ampolish3.
>> It doesn't have that bit set in my tree:
>> $ ls -l ampolish3
>> and I don't see the string uid in that script.  Ralf wrote
>> that script so might have another thought but I am curious if
>> your permissions match on ampolish3.
>> --joel
>>> Thanks,
>>> Neil
>>>> Sent: 02 June 2008 17:02
>>>> To: Neil Mayes
>>>> I'm sure you have told us before but what OS and version Neil?
>>>>>> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
>>>>>> Sent: 02 June 2008 16:54
>>>>>> To: Neil Mayes
>>>>>> Cc: rtems-users at rtems.org
>>>>>> Subject: RE: Error from ampolish3
>>>>>> On Mon, 2008-06-02 at 15:48 +0100, Neil Mayes wrote:
>>>>>>> Hi,
>>>>>>> I have (tried to!) added some device drivers to a BSP
>> (ERC32) and
>>>>>>> wanted to isolate the IO control to a HW API. So the
>>>>>> application would
>>>>>>> just need to include the header and all will be well. Once
>>>>>> I realised
>>>>>>> I needed to regenerate preinstall.am I used bootstrap -p
>>>> however I
>>>>>>> encountered the following error:
>>>>>>> Can't do setuid (cannot exec sperl)
>>>>>> Not from RTEMS. Nothing in RTEMS is using suid-perl.
>>>>>>> Has anyone got an clue where the error is coming from?
>>>>>> Seems to me as if you have a permission problem with your
>>>> source tree
>>>>>> or a problem with your perl installation.
>>>>> I suspect the perl setup :(
>>>>>> Ralf
>>>>> Thanks Ralf
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>    Support Available             (256) 722-9985
