Tool Patches (new user)
Neil Mayes N.Mayes at sstl.co.uk
Fri Jun 6 12:29:08 UTC 2008
Hi Joel,
> Ralf.. could you add some text to the appropriate places in
> the getting started manual?  This seems to be a common
> question these days.
Yep I also got caught by this, I thought it was an initiation to RTEMS
Neil
> Date: Wed, 4 Jun 2008 11:01:46 -0500
> From: Joel Sherrill <joel.sherrill at OARcorp.com>
> Subject: Re: Tool Patches (new user)
> To: Ralf Corsepius <ralf.corsepius at rtems.org>
> Cc: "rtems-users at rtems.com" <rtems-users at rtems.com>,	Paul Dumais
> 	<paul at unstate.ca>
> Message-ID: <4846BC6A.80207 at oarcorp.com>
> Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
> Ralf Corsepius wrote:
> > On Wed, 2008-06-04 at 09:32 -0600, Paul Dumais wrote:
> >> Hi,
> >> I'm trying to figure out which patches to apply to my tool
> set (gcc,
> >> binutils, newlib). I was following allong in the 4.8.0
> documentation
> >> pretty well until it mentioned patches that I should apply that no
> >> longer exist on the server. Could anyone tell me which patches I
> >> should be applying? In general, should I be applying all patches I
> >> can find (chronologically)?
> > No. Only the chronologically latest you intend to use, as
> to be found
> > in contrib/crossrpms/patches from the branch in CVS you
> intend to use.
> >>  Do I assume that the older patches mentioned in the documentation
> >> have been merged into the newer patches? Need I be concerned with
> >> gcc-core?
> > Which OS are you using? We supply binaries and automated
> updates for a
> > variety of OSes.
> Yep. Ralf keeps the build machines working. :)
> > Ralf
> > rtems-users mailing list
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
> End of rtems-users Digest, Vol 21, Issue 5
