Question ~ Using objcopy to convert a .a to .o
Ross A. Osborn rosborn at motorola.com
Fri Jun 6 15:56:47 UTC 2008
On Thu, Jun 05, 2008 at 01:43:18PM -0700, Amalaye Oyake wrote:
> Hello,
> I want to use objcopy to copy some objects from a static library (.a) into a
> standalone object (.o).
> I have a very good reason why I want to do this ... how do I do it though? I
> have only marginally tinkered with objcpy ...
> Any pointers would be appreciated.
Do you mean you have a good reason for extracting object files from an
archive or a good reason for using objcopy to do the job?
It seems to me that objcopy is the wrong tool for this job.  To extract
object files from an archive I would use ar.  If I wanted multiple
object files combined into a single object file then I would use ld.
Ross
