PowerPC exceptions and critical interrupts
Thu Jun 19 16:05:44 UTC 2008
Hi,
sorry for the long silence but the critical exceptions troubled me a lot
in the last days.
Till Straumann wrote:
> Sebastian Huber wrote:
>> Yes, but this is yet another magic place that the BSP developer has to
>> be aware of.
> No. The cpu support takes care of this. If the CPU is one of the
> 'BookE'-style CPUs then
> the mask is changed to include CE and DE.
My experience covers only two BSPs and for them were CPU ==  BSP ;-)
>> Here are some constrains that I assume:
>> C1: Three asynchronous exception types ME, CE and EE with priorities
>> ME > CE > EE. (Debug exceptions DE?)
> Yes.
>> C2: The exception handler code must not be interrupted by a lower
>> priority exception (mostly due to the thread dispatch disable level).
> I don't think the thread-dispatch disable level is an issue here.
> IIRC what can get messed up are the SRRs, i.e., it could be that
> 1)  EE saves IR and MSR into SRRs
> 2)  CE happens, saves IR and MSR into critical SRRs
> 3)  handler is dispatched; if the handler re-enables EE then
>      the values saved in SRRs at 1) could be overwritten by a
>      second EE.
>> C3: To support RTEMS functions and the dispatcher the critical
>> sections in the system core must be protected by
>> rtems_interrupt_{enable, disable}. Thus if we want to use RTEMS within
>> machine check exceptions we have to add MSR_ME to the disable mask.
>> This may result in check stops. This is an inacceptable tradeoff.
> I agree. MSR_ME should always be enabled. This severely limits what a ME
> handler
> is allowed to do but IMO in many cases we don't have to recover from a
> ME which
> can be considered fatal but we do want print diagnostic output. A
> check-stop is most
> undesirable.
>> C4: The asynchronous high level handler share a common stack.
> Just so we can leverage the existing support code (and the whole
> configuration-table
> business etc).
>> The user of critical interrupts has to be very careful not to enable
>> external exceptions since a
>> uint32_t level = _ISR_Get_level();
>> _ISR_Set_level( 0);
>> _ISR_Set_level( level);
>> will not work.
> If we support critical interrupts then the inline routine in irq_supp.h
> could be modified accordingly. All BSPs using the inline routine would
> not have to care.
I don't know how to handle this proper. For my tests I changed it to:
static inline uint32_t   _CPU_ISR_Get_level( void )
  register unsigned int msr;
  _CPU_MSR_GET(msr);
  if (msr & MSR_EE) {
    return 0;
  } else {
    return 1;
static inline void _CPU_ISR_Set_level( uint32_t   level )
  _CPU_MSR_GET(msr);
  if (!(level & CPU_MODES_INTERRUPT_MASK)) {
    msr |= MSR_EE | MSR_E300_CE | MSR_ME;
  }  else {
    msr &= ~MSR_EE;
  _CPU_MSR_SET(msr);
I added MSR_E300_CE and MSR_ME only because _CPU_ISR_Set_level() will be
used to set the initial task MSR. Is there another way to set such bits?
>> The ppc_exc_msr_irq_mask is currently used to protect the stack switch
>> and ISR nest level.
> But the ultimate purpose was using that same mask for
> rtems_interrupt_enable/disable.
> For efficiency reasons I'd suggest to cache the mask in a SPRG.
>> Machine checks are not included in the disable mask (MSR_ME) that is
>> an inconsistency the current implementation for C4.
> Yes.
>> After a review of the code I think that if C2 is true the disabling of
>> all asynchronous exceptions is superfluous. A stack switch would be
>> problematic only if we increment the ISR nest level and perform the
>> stack switch afterwards, because a higher priority exception may
>> assume that a stack switch is not necessary but actually has not occured.
> Not sure I understand how you would make the operation of testing
> whether a switch is
> necessary and doing the switch an atomic operation (you also have to
> take in consideration
> the case where CE tries to switch just while EE switches back).
> I believe I thought about it carefully and came to the conclusion that
> disabling all
> interrupts was necessary (but I could, of course be proven wrong). OTOH,
> I don't see any harm because the critical section is only 7 instructions
> long.
Yes you are right. If we don't disable the exceptions then a high
priority exception may overwrite its own stack if the stack is switched
but the lower priority exception was interrupted before it could write
the new nest level.
I store now the interrupt stack end in SPR2 and check if the exception
stack is in the interrupt stack area. If not then the stack will be
switched:
    /* Switch stack if necessary */
    mfspr    SCRATCH_REGISTER_0, SPRG1
    cmpw    SCRATCH_REGISTER_0, r1
    blt    wrap_stack_switch_\_FLVR
    mfspr    SCRATCH_REGISTER_1, SPRG2
    cmpw    SCRATCH_REGISTER_1, r1
    blt    wrap_stack_switch_done_\_FLVR
wrap_stack_switch_\_FLVR:
    mr    r1, SCRATCH_REGISTER_0
wrap_stack_switch_done_\_FLVR:
The switch back is only (FRAME_REGISTER is the r1 of the exception
prologue which points to the exception frame):
    mr    r1, FRAME_REGISTER
But if old or new the critical exceptions don't work for me. One bug was
in the epilogue. You have to disable all exceptions which may cause a
context switch between the restore of the SRRs and the RFI.
I wrote a test program with several external timers which generate
normal interrupts and one critical. Sometimes the system crashes in a
way that disconnects the Lauterbach debugger.  We tried hard but have
not figured out the error yet. Currently I have no time left so I have
to postpone this issue.
For the other ISR functions I use this:
static inline uint32_t score_powerpc_interrupt_disable()
  uint32_t level;
  uint32_t mask;
  asm volatile (
    "mfmsr %0;"
    "mfspr %1, 272;"
    "andc %1, %0, %1;"
    "mtmsr %1"
    : "=r" (level), "=r" (mask)
  return level;
static inline void score_powerpc_interrupt_enable( uint32_t level)
  asm volatile (
    "mtmsr %0"
    : "r" (level)
static inline uint32_t score_powerpc_interrupt_flash( uint32_t level)
  uint32_t current_level;
  asm volatile (
    "mfmsr %0;"
    "mtmsr %1;"
    "mtmsr %0"
    : "=&r" (current_level)
    : "r" (level)
  return level;
>> The RTEMS support for critical interrupts has its obstacles but is
>> feasible.
> I tried to do prepare for this and I believe the hardest part is already
> done.
> What remains is :
>   - change rtems_interrupt_enable()/disable so that all interrupts are
> masked
>     (I propose to copy ppc_exc_msr_irq_mask -> SPRG0 and then use that to
>     mask and unmask interrupts).
>   - maybe introduce 2 levels of interrupts ('normal' and 'critical') and
> change
>     the inline (irq_supp.h) so that it enables the current level - 1
> instead of enabling
>     level 0.
>> For machine checks I am against to add it due to the check stop
>> problematic.
> Agreed.
> I would like to make these changes soon, i.e., prior to 4.9 being cut
> -- Till
>>> What needs to be done is:
>>>  - eliminate current checks for SPRG0 contents
>>>  - load SPRG0 with ppc_exc_msr_irq_mask (probably from
>>>    initialize_exceptions)
>>>  - convert _CPU_ISR_Set_level, _CPU_ISR_Disable, _CPU_ISR_Enable
>>>    etc. to using SPRG0 instead of a static value.
>>>  - convert the bspsupport to using SPRG0 instead of the
>>>    variable (optional but would be a little bit more efficient and
>>> consistent).
>>> -- Till
>>>> Hi,
>>>> I adapt the gen83xx BSP for the MPC8313E currently. I switched to
>>>> the new support code (libcpu/powerpc/new-exceptions/bspsupport) and
>>>> adjusted it for e300 cores. With this framework it is possible to
>>>> use RTEMS routines and the dispatcher from external and critical
>>>> exceptions (some sophisticated lock variables are involved for
>>>> this).  In order too test it I configured the interrupt controller
>>>> (IPIC) in a way so that for some interrupt sources a critical
>>>> interrupt exception will be generated. This works fine except that
>>>> the current rtems_interrupt_{enable,disable} functions are not aware
>>>> of critical interrupts. This leads to race conditions in the system
>>>> core. I guess that this is also true for Book E critical interrupts.
>>>> A solution is to add the appropriate bits to the disable mask
>>>> (MSR_CE or MSR_E300_CE), but this leads to a preprecessor or runtime
>>>> cpu check orgie. Do we really need RTEMS support in critical or
>>>> machine check exceptions?
>>>> Ciao,
>>>>     Sebastian
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
