Get the output of a program in a file using QEmu
Wed Jun 25 17:21:28 UTC 2008
Reng Zeng wrote:
> It does not work as well with '-serial stdio',
> btw, I also 'make clean' 'make' my program. And, when I make , it
> seems do not have any "USE_COM1_AS_CONSOLE" in it, is that the problem?
You have to clean RTEMS, reconfigure with that added option and remake
your application.
Your application has no idea where the console goes.
> i386-rtems4.9-gcc --pipe -B/opt/rtems-4.9/i386-rtems4.9/pc586/lib/
> -specs bsp_specs -qrtems   -g -Wall  -O2 -g -g    -mtune=pentium
> -c   -o o-optimize/init.o init.c
That looks pretty reasonable.
> Thanks,
> Alan
> 2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>:
>     Reng Zeng wrote:
>         Hi Joel,
>         Thanks for your tips, I tried it as steps below, it still does
>         not work.
>         1.  ../rtems/configure USE_COM1_AS_CONSOLE=1
>         BSP_PRESS_KEY_FOR_RESET=0 --target=i386-rtems4.9
>         --enable-rtemsbsp=pc586 --disable-posix --disable-itron
>         --enable-tests=samples
>         2. make clean
>         3. make
>         4. make install
>         Then I run it my qemu:
>         /usr/bin/qemu -monitor null -nographic -serial file:qemu.log
>         -boot a -m 128 -fda '/home/zengreng/rtems-boot.img' -hda
>         'fat:/home/zengreng/workspace/rtems_tools/src/generated/'
>          --no-reboot
>     Try -serial stdio and see if that works.  Maybe file: doesn't
>     work.  I have never used it.
>         The program to run is managed by Makefile I drafted, not
>         automake, I attached it to see whether that is the cause
>         things do not work, shall I add something like
>         "USE_COM1_AS_CONSOLE" into it as well?
>     There was no program attached but any of the samples should just work
>     that way.
>         Thanks again,
>         Alan
>         <mailto:joel.sherrill at oarcorp.com>>>:
>            Reng Zeng wrote:
>                Hello,
>                It do NOT work for me, I add "#define
>         USE_COM1_AS_CONSOLE 1 "
>                into my init.c, and run qemu by
>                    qemu -nographic -serial file:output.txt -boot a -m 128
>                -fda myimage.img -hda fat:.
>            No.  That's not going to work.  You have to configure with that
>            set on the configure
>            comment line.
>            ..../configure ... USE_COM1_AS_CONSOLE=1
>            The BSP_PRESS_KEY_FOR_RESET=0 configures the BSP to not
>         wait for a key
>            press before resetting.  Just add  --no-reboot to your qemu
>            command line and
>            it will "power down" which is exiting. :-D
>                I did not get anything from output.txt. It run well in
>         graphic
>                mode, but I want the output from the program.
>                I would appreciate if you could shed me some light on
>         my mind :)
>            This is a fragement from the shell script I use.
>            QEMU="/usr/local/bin/qemu -cpu 486"
>            runit()
>             ARGS="-m 8 -boot a -fda ${fd0Image} -hda fat:${hd0Dir} \
>                   -monitor null -nographic -serial stdio --no-reboot"
>              ${QEMU} ${ARGS} >${logfile} 2>&1 &
>                Thanks,
>                Alan
>                2008/3/21 Jean-Claude Grange <lebauce at free.fr
>         <mailto:lebauce at free.fr>
>                <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>
>                <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>>>:
>                   Hello,
>                   Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked
>                just fine.
>                   I'm really interested in your patch, Joel. Are you
>         going to
>                commit it
>                   soon ? Or would you mind sending your patch to me so
>         that I can
>                   test it.
>                   Thanks
>                   See you
>                   Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
>                   > Jean-Claude Grange wrote:
>                   >> Hello,
>                   >> Thanks for your answer. I'll try that.
>                   >> But I wonder if it's possible to do it without
>         modifying the
>                   >> program ?
>                   > Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
>                   > command line and the console will move to the
>         serial port.
>                   > This is how I run RTEMS and GCC tests in an automated
>                   > fashion.
>                   > I discovered another nice qemu option --no-reboot
>         which
>                   > exits when the simulated PC does a reset.  This
>         means you
>                   > get a single run of the application and then it
>         exits.  I
>                have
>                   > a pending patch in my tree to make the BSP reset on
>                   > application exit or exception without waiting for
>         a human
>                   > to press a character.  This sped up the gcc test runs
>                   > by a large factor since they have >50K tests.
>                   > --joel
>                   >> José Marinho <zemanel at gmail.com
>         <mailto:zemanel at gmail.com>
>                <mailto:zemanel at gmail.com <mailto:zemanel at gmail.com>>
>                <mailto:zemanel at gmail.com <mailto:zemanel at gmail.com>>>>
>         wrote:
>                   >>> you can allways create a file, format it to a
>         specific
>                fylesystem
>                   >>> and pass
>                   >>> it to qemu as an hard drive, and tell the rtems
>         program
>                to create
>                   >>> and write
>                   >>> in a file in that hard drive. and then you can mount
>                that file
>                   >>> with loop
>                   >>> device and access it and get the output file. that's
>                the approach
>                   >>> that I'de
>                   >>> take. Hope that's usefull to you
>                   >>> José Marinho
>                   >>> On 16/03/2008, Jean-Claude Grange
>         <lebauce at free.fr <mailto:lebauce at free.fr>
>         <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>>> wrote:
>                   >>>> Hello,
>                   >>>> I'm sorry if this is a stupid question but I've
>                searched on the
>                   >>>> mailing
>                   >>>> list and
>                   >>>> didn't find an answer.
>                   >>>> I'm trying to get the output of a RTEMS program
>         (for
>                example the
>                   >>>> Hello
>                   >>>> from the
>                   >>>> samples testsuite) using QEmu, into a file. I'm
>         using the
>                   >>>> command (on
>                   >>>> Linux) :
>         -fda
>                myimage.img
>                   >>>> -hda
>                   >>>> fat:.
>                   >>>> but I don't get anything in the 'output.txt'
>         file. I
>                also tried -
>                   >>>> serial
>                   >>>> /dev/ttyS* and with the -monitor stdio option but I
>                still have
>                   >>>> nothing. I
>                   >>>> must
>                   >>>> be doing something wrong.
>                   >>>> I would really appreciate your help.
>                   >>>> Thank you
>                   >>>> _______________________________________________
>                   >>>> rtems-users mailing list
>                   >>>> rtems-users at rtems.com
>         <mailto:rtems-users at rtems.com> <mailto:rtems-users at rtems.com
>         <mailto:rtems-users at rtems.com>>
>         <mailto:rtems-users at rtems.com>>>
>                   >>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>                   >>> <img>
>         http://www.deec.uc.pt/common/img/deezoom.gif </img>
>                   > Joel Sherrill, Ph.D.             Director of
>         Research &
>                Development
>                   > joel.sherrill at OARcorp.com        On-Line Applications
>                Research
>                   > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>                   >   Support Available             (256) 722-9985
>                   rtems-users at rtems.com <mailto:rtems-users at rtems.com>
>         <mailto:rtems-users at rtems.com <mailto:rtems-users at rtems.com>>
>            --    Joel Sherrill, Ph.D.             Director of Research
>         & Development
>            joel.sherrill at OARcorp.com        On-Line Applications Research
>     Joel Sherrill, Ph.D.             Director of Research & Development
