Get the output of a program in a file using QEmu
Reng Zeng alan at fiucssa.org
Wed Jun 25 20:42:11 UTC 2008
Hello Joel, Daron,
Thanks for your help. Things work well for me now, after I delete the whole
build directory instead of "make clean".
BTW, it works without '-nographic' to output to stdio, as I use '-serial
stdio', However, with '-nographic', it simply does not work ...
Thanks again,
Alan
2008/6/25 Reng Zeng <alan at fiucssa.org>:
> I remaked all RTEMS code by 'make clean', '../rtems/configure
> USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0 --target=i386-rtems4.9
>        --enable-rtemsbsp=pc586 --disable-posix --disable-itron
>        --enable-tests=samples',
> 'make', 'make install'.
> This 'hello' sample works well for me, in graphical mode:
> qemu -serial stdio -boot a -m 128 -fda '/home/zengreng/rtems-boot.img' -hda
> 'fat:/home/zengreng/pc586/i386-rtems4.9/c/pc586/testsuites/samples/hello'
> --no-reboot
> But with -nographic , it does not work, simply suspending there, no output.
> qemu -nographic -serial stdio -boot a -m 128 -fda
> --no-reboot
> My QEMU version is 0.9.1 as well.
> QEMU PC emulator version 0.9.1, Copyright (c) 2003-2008 Fabrice Bellard
> Your command line work well for me, but it is still graphic mode, I can not
> log the output.
> qemu -boot n -m 128 -tftp
> /home/zengreng/pc586/i386-rtems4.9/c/pc586/testsuites/samples/hello/ -bootp
> /hello.exe -no-reboot -serial stdio
> And when I run it with -nographic,  no any output again.... :(
> /usr/bin/qemu -boot n -m 128 -tftp
> /hello.exe -no-reboot -serial stdio -nographic
> I would appreciate if any more clues for me to figure out the cause.
> Thanks,
> Alan
> 2008/6/25 Daron Chabot <daron.chabot at usask.ca>:
>  What version of Qemu are you using ?
>> To narrow down the problem, try using one of the sample/test programs
>> in /opt/rtems-4.9/i386-rtems4.9/pc586/lib/rtems-4.9/tests (eg: hello.exe).
>> The command line I use with Qemu 0.9.1 is:
>> qemu -no-reboot -m 128 -boot n -tftp
>> /opt/rtems/i386-rtems/pc386/lib/rtems-4.9/tests -bootp /hello.exe -serial
>> stdio
>> -- dc
>> On 25-Jun-08, at 11:11 AM, Reng Zeng wrote:
>> It does not work as well with '-serial stdio',
>> btw, I also 'make clean' 'make' my program. And, when I make , it seems do
>> not have any "USE_COM1_AS_CONSOLE" in it, is that the problem?
>> i386-rtems4.9-gcc --pipe -B/opt/rtems-4.9/i386-rtems4.9/pc586/lib/ -specs
>> bsp_specs -qrtems   -g -Wall  -O2 -g -g    -mtune=pentium     -c   -o
>> o-optimize/init.o init.c
>> Thanks,
>> Alan
>> 2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>> Reng Zeng wrote:
>>>> Hi Joel,
>>>> Thanks for your tips, I tried it as steps below, it still does not work.
>>>> 1.  ../rtems/configure USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
>>>> --target=i386-rtems4.9 --enable-rtemsbsp=pc586 --disable-posix
>>>> --disable-itron --enable-tests=samples
>>>> 2. make clean
>>>> 3. make
>>>> 4. make install
>>>> Then I run it my qemu:
>>>> /usr/bin/qemu -monitor null -nographic -serial file:qemu.log -boot a -m
>>>> 'fat:/home/zengreng/workspace/rtems_tools/src/generated/'  --no-reboot
>>>>  Try -serial stdio and see if that works.  Maybe file: doesn't work.  I
>>> have never used it.
>>>> The program to run is managed by Makefile I drafted, not automake, I
>>>> attached it to see whether that is the cause things do not work, shall I add
>>>> something like "USE_COM1_AS_CONSOLE" into it as well?
>>>>  There was no program attached but any of the samples should just work
>>> that way.
>>>> Thanks again,
>>>> Alan
>>>> 2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com <mailto:
>>>> joel.sherrill at oarcorp.com>>:
>>>>    Reng Zeng wrote:
>>>>        Hello,
>>>>        It do NOT work for me, I add "#define USE_COM1_AS_CONSOLE 1 "
>>>>        into my init.c, and run qemu by
>>>>            qemu -nographic -serial file:output.txt -boot a -m 128
>>>>        -fda myimage.img -hda fat:.
>>>>    No.  That's not going to work.  You have to configure with that
>>>>    set on the configure
>>>>    comment line.
>>>>    ..../configure ... USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
>>>>    The BSP_PRESS_KEY_FOR_RESET=0 configures the BSP to not wait for a
>>>> key
>>>>    press before resetting.  Just add  --no-reboot to your qemu
>>>>    command line and
>>>>    it will "power down" which is exiting. :-D
>>>>        I did not get anything from output.txt. It run well in graphic
>>>>        mode, but I want the output from the program.
>>>>        I would appreciate if you could shed me some light on my mind :)
>>>>    This is a fragement from the shell script I use.
>>>>    QEMU="/usr/local/bin/qemu -cpu 486"
>>>>    runit()
>>>>     ARGS="-m 8 -boot a -fda ${fd0Image} -hda fat:${hd0Dir} \
>>>>           -monitor null -nographic -serial stdio --no-reboot"
>>>>      ${QEMU} ${ARGS} >${logfile} 2>&1 &
>>>>        Thanks,
>>>>        Alan
>>>>        2008/3/21 Jean-Claude Grange <lebauce at free.fr
>>>>         <mailto:lebauce at free.fr> <mailto:lebauce at free.fr
>>>>        <mailto:lebauce at free.fr>>>:
>>>>           Hello,
>>>>           Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked
>>>>        just fine.
>>>>           I'm really interested in your patch, Joel. Are you going to
>>>>        commit it
>>>>           soon ? Or would you mind sending your patch to me so that I
>>>> can
>>>>           test it.
>>>>           Thanks
>>>>           See you
>>>>           Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
>>>>           > Jean-Claude Grange wrote:
>>>>           >> Hello,
>>>>           >> Thanks for your answer. I'll try that.
>>>>           >> But I wonder if it's possible to do it without modifying
>>>> the
>>>>           >> program ?
>>>>           > Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
>>>>           > command line and the console will move to the serial port.
>>>>           > This is how I run RTEMS and GCC tests in an automated
>>>>           > fashion.
>>>>           > I discovered another nice qemu option --no-reboot which
>>>>           > exits when the simulated PC does a reset.  This means you
>>>>           > get a single run of the application and then it exits.  I
>>>>        have
>>>>           > a pending patch in my tree to make the BSP reset on
>>>>           > application exit or exception without waiting for a human
>>>>           > to press a character.  This sped up the gcc test runs
>>>>           > by a large factor since they have >50K tests.
>>>>           > --joel
>>>>           >> José Marinho <zemanel at gmail.com
>>>>         <mailto:zemanel at gmail.com> <mailto:zemanel at gmail.com
>>>>        <mailto:zemanel at gmail.com>>> wrote:
>>>>           >>> you can allways create a file, format it to a specific
>>>>        fylesystem
>>>>           >>> and pass
>>>>           >>> it to qemu as an hard drive, and tell the rtems program
>>>>        to create
>>>>           >>> and write
>>>>           >>> in a file in that hard drive. and then you can mount
>>>>        that file
>>>>           >>> with loop
>>>>           >>> device and access it and get the output file. that's
>>>>        the approach
>>>>           >>> that I'de
>>>>           >>> take. Hope that's usefull to you
>>>>           >>> José Marinho
>>>>           >>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr
>>>>            <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>> wrote:
>>>>           >>>> Hello,
>>>>           >>>> I'm sorry if this is a stupid question but I've
>>>>        searched on the
>>>>           >>>> mailing
>>>>           >>>> list and
>>>>           >>>> didn't find an answer.
>>>>           >>>> I'm trying to get the output of a RTEMS program (for
>>>>        example the
>>>>           >>>> Hello
>>>>           >>>> from the
>>>>           >>>> samples testsuite) using QEmu, into a file. I'm using the
>>>>           >>>> command (on
>>>>           >>>> Linux) :
>>>>           >>>> qemu -nographic -serial file:output.txt -boot a -fda
>>>>        myimage.img
>>>>           >>>> -hda
>>>>           >>>> fat:.
>>>>           >>>> but I don't get anything in the 'output.txt' file. I
>>>>        also tried -
>>>>           >>>> serial
>>>>           >>>> /dev/ttyS* and with the -monitor stdio option but I
>>>>        still have
>>>>           >>>> nothing. I
>>>>           >>>> must
>>>>           >>>> be doing something wrong.
>>>>           >>>> I would really appreciate your help.
>>>>           >>>> Thank you
>>>>           >>>> _______________________________________________
>>>>           >>>> rtems-users mailing list
>>>>           >>>> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
>>>>         <mailto:rtems-users at rtems.com <mailto:rtems-users at rtems.com>>
>>>>           >>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>>>           >>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </img>
>>>>           > Joel Sherrill, Ph.D.             Director of Research &
>>>>        Development
>>>>           > joel.sherrill at OARcorp.com        On-Line Applications
>>>>        Research
>>>>           > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>           >   Support Available             (256) 722-9985
>>>>    --    Joel Sherrill, Ph.D.             Director of Research &
>>>> Development
>>>>    joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Joel Sherrill, Ph.D.             Director of Research & Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20080625/1e208081/attachment.html>
