Error from ampolish3
Neil Mayes
N.Mayes at sstl.co.uk
Mon Jun 2 16:07:19 UTC 2008
Sorry I should have supplied details:
i686-pc-linux RHEL4 & RTEMS4.8.0
Be gentle, linux newbie.
Thanks,
Neil
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 02 June 2008 17:02
> To: Neil Mayes
> Cc: Ralf Corsepius; rtems-users at rtems.org
> Subject: Re: Error from ampolish3
> I'm sure you have told us before but what OS and version Neil?
> >> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> >> Sent: 02 June 2008 16:54
> >> To: Neil Mayes
> >> Cc: rtems-users at rtems.org
> >> Subject: RE: Error from ampolish3
> >> On Mon, 2008-06-02 at 15:48 +0100, Neil Mayes wrote:
> >>> Hi,
> >>> I have (tried to!) added some device drivers to a BSP (ERC32) and
> >>> wanted to isolate the IO control to a HW API. So the
> >> application would
> >>> just need to include the header and all will be well. Once
> >> I realised
> >>> I needed to regenerate preinstall.am I used bootstrap -p
> however I
> >>> encountered the following error:
> >>> Can't do setuid (cannot exec sperl)
> >> Not from RTEMS. Nothing in RTEMS is using suid-perl.
> >>> Has anyone got an clue where the error is coming from?
> >> Seems to me as if you have a permission problem with your
> source tree
> >> or a problem with your perl installation.
> > I suspect the perl setup :(
> >> Ralf
> > Thanks Ralf
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
