mistakes in RTEMS C User's Guide
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Jun 20 17:16:26 UTC 2008
Catalin Morosan wrote:
> Hi.
> I found some minor mistakes in the documentation for the IO Manager.
> In "16.1 Introduction" the rtems_io_unregister_driver directive is not
> mentioned.
> In "16.4.2: IO UNREGISTER DIVER" the name of the directive is
> "rtems_io_register_driver" instead of "rtems_io_*un*register_driver".
> I apologize if this is too irrelevant for this mailing list. What is
> the proper way to submit documentation mistakes?
Documentation errors/typos are never irrelevant. They are often hard to
spot and we appreciate it when they are reported.
Reporting this to the list was sufficient. I have fixed these in all
active branches.
The CVS version of the documentation is available online and rebuilt
twice per day.
Double check that what you spotted is fixed.
Thanks.
