Build error on CVS HEAD
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 23 12:50:47 UTC 2008
Christian Poessinger wrote:
> Hallo,
> when building RTEMS from the CVS HEAD I get the following Compile error
> when invoking 'make all' after '../rtems/configure --target=i386-rtems
> --prefix=/data/RTEMS'
> i386-rtems-gcc --pipe -DHAVE_CONFIG_H -I..
> -I../../cpukit/../../../i386ex/lib/include
> -I../../../../../../rtems/c/src/../../cpukit/libmisc/shell -Wall -fasm
> -msoft-float -O2 -g -MT shell/libshell_a-main_chroot.o -MD -MP -MF
> shell/.deps/libshell_a-main_chroot.Tpo -c -o
> shell/libshell_a-main_chroot.o `test -f 'shell/main_chroot.c' || echo
> '../../../../../../rtems/c/src/../../cpukit/libmisc/'`shell/main_chroot.c
> mv -f shell/.deps/libshell_a-main_chroot.Tpo
> shell/.deps/libshell_a-main_chroot.Po
> -msoft-float -O2 -g -MT shell/libshell_a-main_cp.o -MD -MP -MF
> shell/.deps/libshell_a-main_cp.Tpo -c -o shell/libshell_a-main_cp.o `test
> -f 'shell/main_cp.c' || echo
> '../../../../../../rtems/c/src/../../cpukit/libmisc/'`shell/main_cp.c
> ../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_cp.c: In
> function 'main_cp':
> ../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_cp.c:124:
> error: storage size of 'getopt_reent' isn't known
> ../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_cp.c:127:
> error: 'getopt_data' undeclared (first use in this function)
> error: (Each undeclared identifier is reported only once
> error: for each function it appears in.)
> ../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_cp.c:129:
> warning: implicit declaration of function 'getopt_r'
> warning: unused variable 'getopt_reent'
> make[5]: *** [shell/libshell_a-main_cp.o] Error 1
> make[5]: Leaving directory
> `/home/xcp/Desktop/build-rtems/i386-rtems/c/i386ex/cpukit/libmisc'
> make[4]: *** [all-recursive] Error 1
> make[4]: Leaving directory
> `/home/xcp/Desktop/build-rtems/i386-rtems/c/i386ex/cpukit'
> make[3]: *** [all] Error 2
> make[3]: Leaving directory
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/home/xcp/Desktop/build-rtems/i386-rtems/c/i386ex'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/xcp/Desktop/build-rtems/i386-rtems/c'
> make: *** [all-recursive] Error 1
> # i386-rtems-gcc -v
> Using built-in specs.
> Target: i386-rtems
> Configured with: ../gcc-4.0.1/configure --target=i386-rtems -with-gnu-as
> --with-gnu-ld --with-newlib --verbose --enable-threads
> --enable-languages=c,c++ --prefix=/data/RTEMS
> Thread model: rtems
> gcc version 4.0.1
> Is this a know issue with a workaround availible?
Yes .. you are not using anywhere close to the current tools. That is
an ancient version of gcc and I assume it has a correspondingly ancient
newlib patch. The newlib patch is out of date.
> Best regards,
> Christian
> rtems-users mailing list
> rtems-users at rtems.com
