Get the output of a program in a file using QEmu
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jun 25 16:11:24 UTC 2008
Reng Zeng wrote:
> Hello,
> It do NOT work for me, I add "#define USE_COM1_AS_CONSOLE 1 " into my
> init.c, and run qemu by
> qemu -nographic -serial file:output.txt -boot a -m 128 -fda
> myimage.img -hda fat:.
No. That's not going to work. You have to configure with that set on
the configure
comment line.
..../configure ... USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
The BSP_PRESS_KEY_FOR_RESET=0 configures the BSP to not wait for a key
press before resetting. Just add --no-reboot to your qemu command line and
it will "power down" which is exiting. :-D
> I did not get anything from output.txt. It run well in graphic mode,
> but I want the output from the program.
> I would appreciate if you could shed me some light on my mind :)
This is a fragement from the shell script I use.
QEMU="/usr/local/bin/qemu -cpu 486"
runit()
ARGS="-m 8 -boot a -fda ${fd0Image} -hda fat:${hd0Dir} \
-monitor null -nographic -serial stdio --no-reboot"
${QEMU} ${ARGS} >${logfile} 2>&1 &
> Thanks,
> Alan
> 2008/3/21 Jean-Claude Grange <lebauce at free.fr <mailto:lebauce at free.fr>>:
> Hello,
> Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked just fine.
> I'm really interested in your patch, Joel. Are you going to commit it
> soon ? Or would you mind sending your patch to me so that I can
> test it.
> Thanks
> See you
> Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
> > Jean-Claude Grange wrote:
> >> Hello,
> >> Thanks for your answer. I'll try that.
> >> But I wonder if it's possible to do it without modifying the
> >> program ?
> > Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
> > command line and the console will move to the serial port.
> > This is how I run RTEMS and GCC tests in an automated
> > fashion.
> > I discovered another nice qemu option --no-reboot which
> > exits when the simulated PC does a reset. This means you
> > get a single run of the application and then it exits. I have
> > a pending patch in my tree to make the BSP reset on
> > application exit or exception without waiting for a human
> > to press a character. This sped up the gcc test runs
> > by a large factor since they have >50K tests.
> > --joel
> >> José Marinho <zemanel at gmail.com <mailto:zemanel at gmail.com>> wrote:
> >>> you can allways create a file, format it to a specific fylesystem
> >>> and pass
> >>> it to qemu as an hard drive, and tell the rtems program to create
> >>> and write
> >>> in a file in that hard drive. and then you can mount that file
> >>> with loop
> >>> device and access it and get the output file. that's the approach
> >>> that I'de
> >>> take. Hope that's usefull to you
> >>> José Marinho
> >>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr
> <mailto:lebauce at free.fr>> wrote:
> >>>> Hello,
> >>>> I'm sorry if this is a stupid question but I've searched on the
> >>>> mailing
> >>>> list and
> >>>> didn't find an answer.
> >>>> I'm trying to get the output of a RTEMS program (for example the
> >>>> Hello
> >>>> from the
> >>>> samples testsuite) using QEmu, into a file. I'm using the
> >>>> command (on
> >>>> Linux) :
> >>>> qemu -nographic -serial file:output.txt -boot a -fda myimage.img
> >>>> -hda
> >>>> fat:.
> >>>> but I don't get anything in the 'output.txt' file. I also tried -
> >>>> serial
> >>>> /dev/ttyS* and with the -monitor stdio option but I still have
> >>>> nothing. I
> >>>> must
> >>>> be doing something wrong.
> >>>> I would really appreciate your help.
> >>>> Thank you
> >>>> _______________________________________________
> >>>> rtems-users mailing list
> >>>> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
> >>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> >>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </img>
> > Joel Sherrill, Ph.D. Director of Research & Development
> > joel.sherrill at OARcorp.com On-Line Applications Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
