qemu and netdemo - more details
Peter Mueller
peter.o.mueller at gmx.de
Sun Mar 2 10:07:04 UTC 2008
Hello
here are some more details how my system (Debian) is set-up:
Am 01.03.2008 um 21:23 schrieb Peter Mueller:
> Hello,
> I've developed a simple test program based on netdemo for pc386. It
> basically inits the stack and cyclicly prints out network
> statistics data. When running the app in qemu and sending a
> broadcast ping from Linux to the network I can see that the
> counters show network traffic.
> But the ping sent from Linux times out and seems not to receive a
> reply from the app inside qemu.
> Does someone has an idea what the problem could be? Has someone an
> example on how to setup the network interface for qemu under Linux?
Commandline of qemu: qemu -M isapc -curses -net nic,model=ne2k_isa -
net tap,script=/etc/qemu
-ifup -m 8 -fda ~/floppy.img
The ifup script:
#!/bin/sh
sudo -p "Password for $0:" /sbin/ifconfig $1 192.168.7.1
and my network config in the rtems app:
static struct rtems_bsdnet_ifconfig loopdriver_config = {
"lo0", /* name */
rtems_bsdnet_loopattach, /* attach function */
NULL, /* link to next interface */
"127.0.0.1", /* IP address */
"255.0.0.0", /* IP net mask */
NULL, /* Driver supplies hardware
address */
0 /* Use default driver parameters */
static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61,
0x77 };
* Default network interface
static struct rtems_bsdnet_ifconfig netdriver_config = {
BSP_NE2000_NETWORK_DRIVER_NAME, /* name */
BSP_NE2000_NETWORK_DRIVER_ATTACH, /* attach function */
&loopdriver_config, /* link to next interface */
"192.168.7.44", /* IP address */
"255.255.255.0", /* IP net mask */
ethernet_address, /* Ethernet hardware address */
0, /* Use default driver
parameters */
0, /* mtu */
0, /* rbuf_count */
0, /* xbuf_count */
0, /* port */
9 /* irq */
* Network configuration
struct rtems_bsdnet_config rtems_bsdnet_config = {
&netdriver_config,
NULL,
0, /* Default network task priority */
0, /* Default mbuf capacity */
0, /* Default mbuf cluster capacity */
"rtems", /* Host name */
/* Domain name */
"192.168.7.1", /* Gateway */
"192.168.7.1", /* Log host */
{"192.168.7.1" }, /* Name server(s) */
{"" }, /* NTP server(s) */
Hope this helps better to find the problem.
Thanks,
Peter
Peter Mueller
URL: <http://lists.rtems.org/pipermail/users/attachments/20080302/9ccea66c/attachment.html>
