can not install rtems4.8-tools-autotools-17.exe
阎淼 yanmiaobest at gmail.com
Tue Mar 4 06:49:28 UTC 2008
2008/3/4, Chris Johns <chrisj at rtems.org>:
> ?? wrote:
> > I use the installer, mingw is installed to c:\mingw
> > MSTS is installed to c:\msys\1.0
> > all are their default directory
> That should be ok.
> > It works fine on my laptop, but failed on my workstation. May be it's
> > because I didn't use the administrator account.
> Interesting. It must have done something. Is the RTEMS installer running as
> just a user or the administrator ?
   I run RTEMS installer in my user account. The installer requires
administrator account? I didn't try that.
> > BTW: if I use the mingw tarball, how can I install the devel tools?
> The install checks for the above locations for a few files plus the registry
> if it cannot find the location. I have plans to add a dialog box if it cannot
> be found so you can guide the installer. I have not yet down this work.
> Regards
> Chris
