qemu and netdemo - more details
Thu Mar 6 21:02:20 UTC 2008
Peter Mueller wrote:
> Hello
> here are some more details how my system (Debian) is set-up:
Did you get this working?
> Am 01.03.2008 um 21:23 schrieb Peter Mueller:
>> Hello,
>> I've developed a simple test program based on netdemo for pc386. It
>> basically inits the stack and cyclicly prints out network statistics
>> data. When running the app in qemu and sending a broadcast ping from
>> Linux to the network I can see that the counters show network traffic.
>> But the ping sent from Linux times out and seems not to receive a
>> reply from the app inside qemu.
>> Does someone has an idea what the problem could be? Has someone an
>> example on how to setup the network interface for qemu under Linux?
> Commandline of qemu: qemu  -M isapc -curses -net nic,model=ne2k_isa
> -net tap,script=/etc/qemu
> -ifup -m 8 -fda ~/floppy.img
> The ifup script:
> #!/bin/sh
> sudo -p "Password for $0:" /sbin/ifconfig $1 192.168.7.1
> and my network config in the rtems app:
> static struct rtems_bsdnet_ifconfig loopdriver_config = {
>         "lo0",                    /* name */
>         rtems_bsdnet_loopattach,  /* attach function */
>         NULL,                     /* link to next interface */
>         "127.0.0.1",              /* IP address */
>         "255.0.0.0",              /* IP net mask */
>         NULL,                     /* Driver supplies hardware address */
>         0                         /* Use default driver parameters */
> static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
>  * Default network interface
> static struct rtems_bsdnet_ifconfig netdriver_config = {
>         BSP_NE2000_NETWORK_DRIVER_NAME,          /* name */
>         BSP_NE2000_NETWORK_DRIVER_ATTACH,        /* attach function */
>         &loopdriver_config,               /* link to next interface */
>         "192.168.7.44",                     /* IP address */
>         "255.255.255.0",                /* IP net mask */
>         ethernet_address, /* Ethernet hardware address */
>         0,                              /* Use default driver
> parameters */
>         0, /* mtu */
>         0, /* rbuf_count */
>         0, /* xbuf_count */
>         0, /* port */
>         9 /* irq */
>  * Network configuration
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>         &netdriver_config,
>         NULL,
>         0,                      /* Default network task priority */
>         0,                      /* Default mbuf capacity */
>         0,                      /* Default mbuf cluster capacity */
>         "rtems",                  /* Host name */
> /* Domain name */
>         "192.168.7.1",          /* Gateway */
>         "192.168.7.1",                                  /* Log host */
>         {"192.168.7.1" },       /* Name server(s) */
>         {"" },       /* NTP server(s) */
> Hope this helps better to find the problem.
> Thanks,
> Peter
> Peter Mueller
> peter.o.mueller at gmx.de <mailto:peter.o.mueller at gmx.de>
