qemu and netdemo - more details
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 7 18:09:20 UTC 2008
Peter Mueller wrote:
> Hello,
> Am 06.03.2008 um 22:02 schrieb Joel Sherrill:
>>> Hello
>>> here are some more details how my system (Debian) is set-up:
>> Did you get this working?
> Rtems on Debian? Yes no problem
> Any idea on the qemu issue?
I have used qemu networking but not since I got a new laptop so
some of these details are from notes and not tested TODAY. :-D
Attached is the networkconfig-qemu.h that is in CVS with the
network demos. One key issue is the IRQ number on the
configuration. The default in qemu doesn't match the driver in
RTEMS default.
I also recall some qemu documentation or FAQ not being
right or being confusing about the assignment of IP addresses
in the virtual subnet inside qemu.
/etc/qemu-ifup:
#!/bin/sh
TUN_DEV=$1
TUN_HOST=10.0.2.2
/sbin/ifconfig $TUN_DEV $TUN_HOST
exit 0
Command line:
qemu -M isapc -m 8 \
-boot a -fda /home/joel/qemu/pc386_fda \
-hda fat:/home/joel/qemu/hd \
-net nic,macaddr=00:80:7F:22:61:77 \
-net tap,script=/etc/qemu-ifup \
-serial stdio
Any obvious differences from yours?
> Regards,
> Peter
> Peter Mueller
> peter.o.mueller at gmx.de <mailto:peter.o.mueller at gmx.de>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080307/15d6103c/attachment.bin>
