PowerPC exceptions: various comments
Kate Feng feng1 at bnl.gov
Wed Mar 12 15:22:15 UTC 2008
Thomas Doerfler wrote:
> Before we got further into the details of these plans, I would like to
> get your opinion on the whole direction. Be assured, that we would NOT
> add conditional assembly and we would NOT copy/paste/modify relevant
> code :-)
It is #1 and intelligent to have a unified standard throughout the RTEMS
code.
Kate
>Hello Till,
>we are currently adapting RTEMS to a MPC55xx microcontroller with a
>e200z6 CPU core. We are pleased to see, that you have significantly
>cleaned up the PPC exception code and you also already have done lots of
>stuff to support the e500 core, which is very similar to the e200.
>All in all I agree, that your modifications simplify the use of the PPC
>vectoring scheme.
>But we have some topics that should be discussed.
>1. Critical Interrupts
>My colleague Sebastian has tripped over the synchronization you try to
>achieve between non-critical and critical interrupts. As far as I
>understand, you try to detect the situation, that a critical interrupt
>interrupts the prolog code of a non-critical interrupt. For this
>purpose, you write the content of r1 to the "lock_bits" flag as the
>first opcode in the non-critical interrupt prolog.
>Unfortunately this will not work reliable. I have discussed the issue
>with one of my Freescale contact persons, and he told me that entering
>the non-critical interrupt and executing the first opcode is NOT atomic.
>So there is still a chance, that
>- the CPU has saved PC/MSR into SRR0/1
>- the CPU has modified PC/MSR to execute the non-critical interrupt prolog
>- A critical interrupt is raised
>- the CPU saves PC/MSR into CSRR0/1 and enters the critical interrupt
>handler
>- the critical interrupt handler may issue a thread dispatch when
>leaving, and therefore delay the previously raised non-critical interrupt.
>As far as I can see, we should postulate, that critical interrupts are
>NOT allowed to dispatch tasks. Do you see hard requirements that stand
>against this?
>2. Interrupt Prolog Placement in ROM
>Our target will have 128KByte(!) of internal RAM. In some applications,
>this will be the only RAM available, and therefore I am looking for ways
>to place the exception prologue code in ROM/Flash (that's where the rest
>of the code is located anyway).
>What I have seen in the current code gives me the impression that the
>prologue code is more or less statically initialized. When the current
>CPU type has been detected, the corresponding prologue snippets are
>copied to the proper vector locations and it is not intended that the
>prologue code is replaced when e.g. a debugger agent is attached.
>Instead, the agent would connect to the high level handler. Did I get
>this right?
>So my idea would be to alternatively make the macro assembler duplicate
>the prologues in proper flavour, quite similar to the
>"xxx_vector_categories" tables in raw_exception.c. Many other changes
>would be required then (e.g. the relationship between the prologue
>address and the vector number will become different again), but it is at
>least worth the effort for the MPC55xx, and maybe it would even make
>sense for the "big" PPCs, because copying the code to the vector range
>is not really necessary in all situations.
>code :-)
>wkr,
>Thomas.
