Sample example not working: fileio.exe
Wed Mar 12 18:45:04 UTC 2008
Till Straumann wrote:
> Did you look at PR649?
Thanks.    It doesn't hang anymore but now how do I
mount:
RTEMS SHELL (Ver.1.0-FRC):/dev/console. Mar 12 2008. 'help' to list
commands.
SHLL [/] # ls /dev/
-rwxr-xr-x   1   root   root           0 Jan 01 00:00 console
-rwxr-xr-x   1   root   root           0 Jan 01 00:00 ide0
2 files 0 bytes occupied
SHLL [/] # mkdir /mnt
SHLL [/] # mount -t msdos /dev/ide0 /mnt
mount: mount failed: Block device required
SHLL [/] #
And for those who haven't tried the RTEMS shell recently, that is
a command line interface with the recently added capability to
execute simple script files. :D
--joel
> T.
> Joel Sherrill wrote:
>> Thomas,
>> It is probably just a setup issue on my side but the IDE
>> driver locks up during initialization on qemu before Init
>> runs.
>> Program received signal SIGINT, Interrupt.
>> ata_process_request_on_init_phase (ctrl_minor=0, areq=0x15da10)
>> at ../../../../../current/c/src/libchip/ide/ata.c:1422
>> 1422 (!(byte & IDE_REGISTER_STATUS_DRDY)));
>> (gdb) bt
>> #0 ata_process_request_on_init_phase (ctrl_minor=0, areq=0x15da10)
>> #1 0x0010683c in ata_initialize (major=3, minor_arg=0, args=0x0)
>> at ../../../../../current/c/src/libchip/ide/ata.c:1291
>> #2 0x0011109b in _IO_Initialize_all_drivers ()
>> at ../../../../../../current/c/src/../../cpukit/sapi/src/io.c:97
>> #3 0x00111046 in rtems_initialize_executive_early (
>> configuration_table=0x144460)
>> at ../../../../../../current/c/src/../../cpukit/sapi/src/exinit.c:239
>> #4 0x00108d3c in boot_card (argc=0, argv=0x0, envp=0x0)
>> at
>> ../../../../../../../../current/c/src/lib/libbsp/i386/pc386/../../shared/bootcard.c:91
>> #5 0x00100071 in zero_bss ()
>> at
>> ../../../../../../../../current/c/src/lib/libbsp/i386/pc386/start/start.S:184
>> #6 0x00000000 in ?? ()
>> Stepping into the check, I see this:
>> (gdb) s
>> 102 uint32_t port = IDE_Controller_Table[minor].port1;
>> (gdb) s
>> 105 if (reg == IDE_REGISTER_DATA_WORD) {
>> (gdb) s
>> 111 inport_byte(port+reg, bval1);
>> (gdb) p port
>> $1 = 496
>> (gdb) p reg
>> $2 = 7
>> (gdb) p/x port
>> $3 = 0x1f0
>> So it is hanging on the first IDE interface's status.
>> My qemu invocation is:
>> qemu -M isapc -m 8 -boot a -fda /home/joel/qemu/pc386_fda \
>> -hda fat:/home/joel/qemu/hd -serial stdio -s
>> I don't know if this is THE problem here or not but it is
>> stopping for me. :)
>> --joel
>> Thomas Doerfler wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Vinod,
>>> can you give us more information about the disk/disks and interfaces
>>> installed in that computer?
>>> wkr,
>>> Thomas.
>>> Vinod Kulkarni schrieb:
>>> | Hi Thomas,
>>> |     Yes, I am testing it on 386 PC (computer).
>>> | Regards
>>> | Vinod
>>> | -----Original Message-----
>>> | From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
>>> | Sent: Wednesday, March 12, 2008 4:58 PM
>>> | To: vinodk at tataelxsi.co.in
>>> | Cc: rtems-users at rtems.com
>>> | Subject: Re: Sample example not working: fileio.exe
>>> | Vinod,
>>> | one thing you should check: currently the disk interface is based on a
>>> | IDE driver. Do you possibly have fileio.exe running on a machnie, that
>>> | has a modified disk interface (like SATA...). I have no experience, how
>>> | the RTEMS driver would cooperate with NON-PATA Interfaces.
>>> | wkr,
>>> | Thomas.
>>> | | Hi,
>>> | |     I have built RTEMS for i386 (pc386) on Linux. I could execute sample
>>> | | examples such as hello.exe. However, when I tried to execute
>>> fileio.exe, I
>>> | | am not able to see any output on the console. But as per the document
>>> | | fileio.doc, it needs to display options such as "s" etc. Could
>>> anyone tell
>>> | | me what could be the problem?
>>> | | Regards
>>> | | Vinod
>>> | | The information contained in this electronic message and any
>>> | attachments to this message are intended for the exclusive use of the
>>> | addressee(s) and may contain proprietary, confidential or privileged
>>> | information. If you are not the intended recipient, you should not
>>> | disseminate, distribute or copy this e-mail. Please notify the sender
>>> | immediately and destroy all copies of this message and any attachments
>>> | contained in it.
>>> | | Contact your Administrator for further information.
>>> | | _______________________________________________
>>> | | rtems-users mailing list
>>> | | http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> The information contained in this electronic message and any attachments
>>> to this message are intended for the exclusive use of the addressee(s)
>>> and may contain proprietary, confidential or privileged information. If
>>> you are not the intended recipient, you should not disseminate,
>>> distribute or copy this e-mail. Please notify the sender immediately and
>>> destroy all copies of this message and any attachments contained in it.
>>> IMD Ingenieurbuero fuer Microcomputertechnik
>>> Thomas Doerfler           Herbststrasse 8
>>> D-82178 Puchheim          Germany
>>> email:    Thomas.Doerfler at imd-systems.de
>>> PGP public key available at:
>>> ~     http://www.imd-systems.de/pgpkey_en.html
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.3 (MingW32)
>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>>> iD8DBQFH188bwHyg4bDtfjQRAk67AJ0epgjbJBPv/tYPVkkohUz5TcrosACcDUGM
>>> zJzx80ixdHALZC75tWxx64E=
>>> =ewYD
>>> -----END PGP SIGNATURE-----
