MSYS tools installation crashes
Mon Mar 17 23:27:23 UTC 2008
Thomas Doerfler wrote:
> now I have to answer my own posting:
> We found a strange answer to our problem, googling for MSYS and shell
> crashes:
> http://osdir.com/ml/gnu.mingw.msys/2007/msg00056.html
> Obviously the logitech webcam software installed and running on that
> machine influenced the behaviour of the MSYS environmnet.
> Killing the running process "lvprcsrv.exe" made the MSYS system run
> properly again.
Nice find. These sorts of problems can be difficult to resolve.
> Hm.
> I should have thought about it before. Should I ? Anybody has an idea
> what is the link between these two pieces of software?
No idea and I suspect no real way of figuring it out without a long and costly
process. There is always a risk this can happen when adding an emulation layer
to any system and MSYS (which is a fork of cygwin) is no different. I have
seen problems with PC Tools Spyware tools where certain scripts would result
in a crash. Disabling PC Tools did little, I had to uninstall it.
The fault may not lie in MSYS (or Cygwin) how-ever the finger is pointed at
them as they display the crash.
> Well, anyway, the system seems to run MUCH better now. And maybe this
> posting will avoid others to spend more time than neccesary to come
> around this trap.
Great. The actual tools should give you few issues like this as they are
Windows native executables.
Regards
