Multiprocessing for SPARC/ERC32
Sylvain Jouanneau
sylvain.jouanneau at webmail.alten.fr
Thu Mar 20 14:03:47 UTC 2008
Hello,
I'm developing an application to test multiprocessing purpose of RTEMS for
SPARC/ERC32 CPU.
I'm using RTEMS 4.0.0 with compiler ERC32CCS 2.0.6 on Solaris.
I developed an MPCI layer to allow communication via Ethernet between 2
CPUs.
My problem is that when I configure RTEMS for multiprocessing, at the end of
function rtems_initialize_executive_early my Init task is launched
immediately after call of rtems_task_start in
_RTEMS_tasks_Initialize_user_tasks.
At this moment, multitasking mode is not allowed : we didn't passed into
rtems_initialize_executive_late function. And when we pass into it,
segmentation fault arrives because my Init task is already launched.
When I don't configure RTEMS for multiprocessing, I see that Init task is
launched only when multitasking is allowed after call of
_Thread_Start_multitasking in rtems_initialize_executive_late.
Can anyone help me?
Sylvain
Le pr?sent message et ses pi?ces jointes sont confidentiels et exclusivement destin?s ? la personne ou aux personnes vis?e(s) ci-dessus.
Il peut contenir des informations privil?gi?es, confidentielles ou autres, qui ne peuvent ?tre divulgu?es.
Si vous avez re?u ce message par erreur, veuillez contacter imm?diatement l'exp?diteur et effacer le message de votre syst?me sans en faire de copie.
Vous n'?tes pas autoris?(s) ? faire un quelconque usage de son contenu, ni le diffuser, ni en prendre aucune copie, ?lectronique ou autre.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
It may constitute information that is privileged or confidential or otherwise legally exempt from disclose.
If you have received this email in error, please contact the sender and delete the email from your system without copying it.
You are not authorized to read, copy or disseminate this message or any part of it.
