ARM946E-S attempt (gdb patches / insight)
gds gds at chartertn.net
Mon Mar 24 14:44:29 UTC 2008
In my attempt to build an ARM946E-S bsp I hijacked the existing csb337
bsp as a starting point. I have built an arm-rtems4.8-insight debugger
in addition to the standard gdb. However, I never applied the rtems
gdb6.6 patches to the insight 6.6 tree. Are they needed with insight?
Anyhow, when running insight debugger I seems that, in "mixed mode", I
don't always see the assembly instructions associated with the correct
source line. The order seems somewhat random and jumps around when I
step. In the attached example you can see that the instructions
associated with a c source line are not always sequentially increasing.
Would that be expected with arm architecture, which I have not worked
with before? Would lack of rtems patches affect this?
The code shown in ex.txt is from bspstart.c.
-gene
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20080324/07657a59/attachment.txt>
