Eclipse GSOC Projects
Till Straumann strauman at slac.stanford.edu
Mon Mar 24 18:34:38 UTC 2008
Daron Chabot wrote:
-- snip --
>> 2. GNU debugger integration. This can be accomplished using the Zylin
>> Embedded CDT plugin:
>> http://www.zylin.com/embeddedcdt.html
>> I'm not sure if there are any other RTEMS specific things that could
>> enhance the debugger interface in Eclipse. Perhaps when using CEXP
>> and the RTEMS GDB stub, you can build a module and click a button to
>> download it to the target?
> I didn't try very hard, but I could not get Till's GDB stub + Cexp to
> work within Eclipse.
Where did you stumble ?
T.
-- snip --
