Another GSOC application
Sven.BIEBAUT at be.thalesgroup.com Sven.BIEBAUT at be.thalesgroup.com
Wed Mar 26 15:57:45 UTC 2008
> -----Original Message-----
> From: rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] On Behalf Of Joel Sherrill
> Sent: 26 March, 2008 16:30
> To: Sven.BIEBAUT at be.thalesgroup.com
> Cc: rtems-users at rtems.com
> Subject: Re: Another GSOC application
> Sven.BIEBAUT at be.thalesgroup.com wrote:
> >     <snip>
> >      Another idea concerns a project that may become my
> Undergraduate
> >     Thesis. I've been thinking in adapting I-Logix Rhapsody in order
> >     to have a UML tool (with great code-generation capabilities) for
> >     rtems on erc32. This would make possible the use of modern
> >     Software Engineering concepts, leading to fast model-driven
> >     development and analysis of real-time embedded software.
> >      <snip>
> >     André Keller
> >     Hello,
> >     This IMHO could do wonders for the adoption of  RTEMS
> on a lot of
> >     avionics/military projects where Rhapsdy is very much used. The
> >     great thing about an adaptor in rhapsody is that it
> only abstracts
> >     the OS API, which means that as soon as it is written, it is
> >     peanuts to have it on others as you only need to select a new
> >     build environment. Since this is gcc for all RTEMS, you
> only need
> >     to modify a few batch files/scripts to add a cpu.
> >     As Telelogic (formerly known as i-logix) has a mingw
> based adaptor
> >     for win32 console applications, the necessary batchfiles can be
> >     adapted from there to make it work. I do not know if there are
> >     license issues with that approach. That might need to
> be verified.
> Sven .. do you have any contacts that could let Andre do this
> for them as a summer job?
I'm afraid I cant be of much help there. Although we use rhapsody, there is
no project with us that uses RTEMS.
But Telelogic is quite reasonable with evaluation (30 day) licenses which is
about the time needed to develop and test such an adapter if you have prior
knowledge of the OS and its build environment.
> >     HTH,
> >     Sven Biebaut
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
> rtems-users mailing list
