Another GSOC application
André Keller Abadie
akabadie at gmail.com
Thu Mar 27 01:08:58 UTC 2008
Hi Sven
> But Telelogic is quite reasonable with evaluation (30 day) licenses which
is
> about the time needed to develop and test such an adapter if you have
prior
> knowledge of the OS and its build environment.
That would not be the case since I have access to an academic license at my
university.
> > This IMHO could do wonders for the adoption of RTEMS
> on a lot of
> > avionics/military projects where Rhapsdy is very much used. The
> > great thing about an adaptor in rhapsody is that it
> only abstracts
> > the OS API, which means that as soon as it is written, it is
> > peanuts to have it on others as you only need to select a new
> > build environment. Since this is gcc for all RTEMS, you
> only need
> > to modify a few batch files/scripts to add a cpu.
Actually the adaptor is more than
this. Since Rhapsody has model debugging features, great part of the
work would be bsp-dependent, because it'll need to load the
application in the target and then control its activities remotely.
Nevertheless, if well documented and
coded, the amount of time/work needed to include support for other
bsps would be almost insignificant.
Regards,
André--
On 3/26/08, Sven.BIEBAUT at be.thalesgroup.com <Sven.BIEBAUT at be.thalesgroup.com>
wrote:
> > -----Original Message-----
> > From: rtems-users-bounces at rtems.org
> > [mailto:rtems-users-bounces at rtems.org] On Behalf Of Joel Sherrill
> > Sent: 26 March, 2008 16:30
> > To: Sven.BIEBAUT at be.thalesgroup.com
> > Cc: rtems-users at rtems.com
> > Subject: Re: Another GSOC application
> > Sven.BIEBAUT at be.thalesgroup.com wrote:
> > > <snip>
> > > Another idea concerns a project that may become my
> > Undergraduate
> > > Thesis. I've been thinking in adapting I-Logix Rhapsody in order
> > > to have a UML tool (with great code-generation capabilities) for
> > > rtems on erc32. This would make possible the use of modern
> > > Software Engineering concepts, leading to fast model-driven
> > > development and analysis of real-time embedded software.
> > > <snip>
> > > André Keller
> > > Hello,
> > on a lot of
> > only abstracts
> > only need
> > > As Telelogic (formerly known as i-logix) has a mingw
> > based adaptor
> > > for win32 console applications, the necessary batchfiles can be
> > > adapted from there to make it work. I do not know if there are
> > > license issues with that approach. That might need to
> > be verified.
> > Sven .. do you have any contacts that could let Andre do this
> > for them as a summer job?
> I'm afraid I cant be of much help there. Although we use rhapsody, there
> is
> no project with us that uses RTEMS.
> is
> prior
> > > HTH,
> > > Sven Biebaut
> > Joel Sherrill, Ph.D. Director of Research & Development
> > joel.sherrill at OARcorp.com On-Line Applications Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
> > rtems-users mailing list
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20080326/435b4589/attachment.html>
