erc32 wrong compilation flags for initial task with fpu?
Aleix Conchillo Flaqué aconchillo at ieec.cat
Thu Mar 27 14:25:04 UTC 2008
On Thu, Mar 27, 2008 at 2:08 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  Did you every configure the attributes of the initialization
>  task to be floating point or where you just getting lucky?
>  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
For sure.
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_LOCAL | RTEMS_FLOATING_POINT
As I said, with 4.6.1, 4.6.2 and 4.6.4 the application worked fine.
After the SPARC update in 4.6.5 it just failed at the initialisation
task (which uses fpu). Removing the -msoft-float from 4.6.6 solved the
problem.
Yesterday I looked at the patch for the whole afternoon and I did not
see anything else that could affect, but I am not an expert in RTEMS
internals, so probably I am missing something.
Aleix
