cpuuse, rtmonuse and gcc
Aleix Conchillo Flaqué
aconchillo at ieec.cat
Fri Mar 28 15:16:21 UTC 2008
I think the patch attached should do for 4.6.6. I have only applied
the necessary changes to solve the floating point issue.
Aleix
On Fri, Mar 28, 2008 at 3:17 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Aleix Conchillo Flaqué wrote:
> > I am using REMS 4.6.6 with the PR#1237 patch.
> Then you have a version using floating point. Check out
> the code on the CVS head. It is using integer math only.
> If you don't want to do the backport, email me privately and
> we can discuss arranging me to do it for you. It is what
> keeps my kids fed.
> --joel
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080328/05249a93/attachment.bin>
