Requesting for Review of the proposal submitted to dashboard
x ray
rayx.cn at gmail.com
Mon Mar 31 08:25:17 UTC 2008
Greetings,
In fact, I think you have writen a very good proposal. And you have already
covered all the details. Maybe I can only pick some bones from an egg.
1) Text arrangement. Seems you have add some extra carriage return at
end of line, so when I use a different font, the end of each line will be
misaligned. You can delete the return inside paragraph. However, it is
acceptable even if you do not del them.
2) A little bit too long. :P (English is my second language). Btw,I
believe there is some restrains about the length…
3) Will you design new test case to test your codes, or the current
testsuit will cover your code.
2008/3/31, Madhusudan C.S <madhusudancs at gmail.com>:
> Hi Joel, Daron, Ray and all the mentors,
> I submitted my proposal for RTEMS, Adding 64-bit Timestamps
> project on Friday. I haven't recieved any comments till now from any of the
> mentors on what is not clear and what needs to be improved. I request all
> the mentors to go through my proposal and suggest any corrections and
> changes, and also tell me if any part of the proposal is not clear, since
> hardly 16 hours is left for the deadline for recieving proposals so that I
> can change the parts of the proposal thats not clear before the deadline.
> Thanks and regards,
> Madhusudan.C.S
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080331/6e50e483/attachment.html>
