What is "no" application? nm?
Leon Pollak leonp at plris.com
Mon Mar 31 15:17:31 UTC 2008
Hello, all.
While compiling my BSP under 4.8.0 the compilation fails on the following
message:
no -g -n hello.exe > hello.num
/bin/sh: no: command not found
gmake[5]: *** [hello.exe] Error 127
gmake[5]: Leaving directory
`/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites/samples/hello'
gmake[4]: *** [install-recursive] Error 1
gmake[4]: Leaving directory
`/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites/samples'
gmake[3]: *** [install-recursive] Error 1
gmake[3]: Leaving directory
`/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites'
gmake[2]: *** [install-recursive] Error 1
gmake[2]: Leaving directory `/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247'
gmake[1]: *** [install-recursive] Error 1
gmake[1]: Leaving directory `/opt/rtems-4.8.0/build/powerpc-rtems/c'
make: *** [install-recursive] Error 1
I guess that 'no' should be "nm", but my search in makefiles did not give such
string...:-(
Please, where is the problem?
Leon
