gcc-4.3.0/ppc32 inline assembly produces bad code
Till Straumann strauman at slac.stanford.edu
Mon Mar 31 15:40:44 UTC 2008
Andreas Schwab wrote:
> Till Straumann <strauman at slac.stanford.edu> writes:
>> /* Powerpc I/O barrier instruction */
>> #define EIEIO(pmem) do { asm volatile("eieio":"=m"(*pmem):"m"(*pmem)); }
>> while (0)
> Looking closer, your asm statement has a bug.  The "m" constraint can
> match memory addresses with side effects (auto inc/dec), but the insn
> does not carry out that side effect.
I'm sorry - that's a bit too brief for me to understand. Are you
talking about the memory-input or memory-output operand?
Could you please elaborate a little bit?
Also, did you look at my other example?
void
test(volatile unsigned *base)
   volatile unsigned *reg_p = base + IEVENT_REG/sizeof(*base);
   unsigned           val;
   /* tell gcc that the asm needs/looks at *reg_p */
   asm volatile ("lwz %0, 16(%1)":"=r"(val):"b"(base),"m"(*reg_p));
   while ( ! (val & IEVENT_GRSC) )
       val = *reg_p;
Thanks
-- Till
>   On powerpc the side effect must be
> encoded through the update form of the load/store insns.  If you don't
> use a load or store insn with the operand the you must use the "o"
> constraint to avoid the side effect.
> Andreas.
