What is "no" application? nm?
Leon Pollak leonp at plris.com
Mon Mar 31 16:06:15 UTC 2008
Ralf,
Thank you for reply, but I am affraid that the issue is a bit different:
I checked - powerpc-rtems-nm IS in the path. And it does not work. But if I
add the link in the same directory where the powerpc-rtems-nm resides to
itself and call it 'no', everything works fine till the end!
On Monday, 31 בMarch 2008, Ralf Corsepius wrote:
> On Mon, 2008-03-31 at 18:17 +0300, Leon Pollak wrote:
> > Hello, all.
> > While compiling my BSP under 4.8.0 the compilation fails on the following
> > message:
> > no -g -n hello.exe > hello.num
> > /bin/sh: no: command not found
> > gmake[5]: *** [hello.exe] Error 127
> > gmake[5]: Leaving directory
> > `/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites/samples/hello
> >' gmake[4]: *** [install-recursive] Error 1
> > gmake[4]: Leaving directory
> > `/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites/samples'
> > gmake[3]: *** [install-recursive] Error 1
> > gmake[3]: Leaving directory
> > `/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247/testsuites'
> > gmake[2]: *** [install-recursive] Error 1
> > gmake[2]: Leaving directory
> > `/opt/rtems-4.8.0/build/powerpc-rtems/c/FDR_8247' gmake[1]: ***
> > gmake[1]: Leaving directory `/opt/rtems-4.8.0/build/powerpc-rtems/c'
> > make: *** [install-recursive] Error 1
> > I guess that 'no' should be "nm",
> Almost, it should be your target's nm (powerpc-rtems4.8-nm).
> > but my search in makefiles did not give such
> > string...:-(
> > Please, where is the problem?
> Probably in your toolchain installation.
> Very likely, you either don't have your toolchain installed correctly or
> you PATH is set up incorrectly.
> If using the rpms, you should have /opt/rtems-4.8/bin (the directory
> containing <target>-nm) in $PATH.
> Ralf
            Dr.Leon M.Pollak
                Director
       PLR Information Systems Ltd.
Tel.:+972-98657670  |  POB 8130, H'Aomanut 9,
Fax.:+972-98657621  |  Poleg Industrial Zone,
Mob.:+972-544739246 |  Netanya, 42160, Israel.
