How to specify offset into SPI device
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Tue Mar 11 16:31:17 UTC 2008
Robert,
Robert S. Grimes schrieb:
> Thomas Doerfler wrote:
>> wow, you made a long way :-) Sorry for not answering, you were still on
>> my "TODO" List.
> No problem - the problem with lists is they tend to grow faster than we
> can prune them!
Yes, this leaves LOT of stuff over for future generations to dig out
again :-)
>> The RTEMS I/O system will pack the offset required into the "args"
>> structure passed to the memory driver.
>> So the write call just has to use the elements of arg.
> Yes, I saw this in the SPI EPROM driver. But how do I tell the RTEMS
> I/O system what the offset is? I added another printk to the fram read
> and write routines, and I get messages like these:
> Write 12 bytes to 0
> Write 13 bytes to 0
> when I ran:
> write(fd, buffer1, 12);
> write(fd, buffer2, 13);
> As you might surmise, this indicates that the length information (i.e.
> 12 and 13 in these examples) makes it into the fram driver, but the
> offset is always 0. I'm clearly missing something here...
I guess, that you do not (yet) advance the rwargs->bytes_moved element?
Without looking at the RTEMS I/O code, I guess that it learns from that
parameter, how far you have actually written to the file/device.
> I looked at your code, and it's a great improvement! I only wrote mine
> because it was almost trivial to adapt the existing driver, and I needed
> something I could understand to "drive" my SPI driver development. I
> will almost certainly end up with yours, though, once you get it into
> the tree.
Fee free to use it as is now :-)
wkr,
Thomas.
> Thanks again!
> -Bob
>> wkr,
>> Thomas.
>> | Okay, I've got most of this figured out. This code works, in that it
>> | invokes the correct driver calls:
>> | int fd = open("/dev/spi.fram", O_RDWR);
>> | printf("open returned %d\n", fd);
>> | if (fd >= 0) {
>> | char buffer[32];
>> | char rbuffer[32];
>> | strcpy(buffer, "Hello world");
>> | strcpy(rbuffer, "Uh, oh.....");
>> | printf("ioctl returned %d\n", ioctl(fd, SEEK_SET, 0x200));
>> | printf("write returned %d\n", write(fd, buffer, 4));
>> | printf("read returned %d\n", read(fd, rbuffer, 4));
>> | printf("rbuffer = [%s]\n", rbuffer);
>> | close(fd);
>> | This gives the following output:
>> | open returned 4
>> | ioctl returned -1
>> | fram write
>> | bsp_spi_send_start_dummy: Implement me!
>> | bsp_spi_sel_addr: Implement me!
>> | bsp_spi_send_stop: Implement me!
>> | write returned 4
>> | ioctl returned -1
>> | fram read
>> | read returned 0
>> | rbuffer = [Uh, oh.....]
>> | The lines starting with "fram" or "bsp_spi_XXX" are debugging outputs
>> | from the drivers I'm working on. So, everything is set up to actually
>> | access the device! Yes!
>> | The next question is this: how do I specify the offset into the FRAM? I
>> | guessed it's in an ioctl call, as suggested in libi2c.h, but as you can
>> | see, that doesn't work. Stepping through, it seems ioctl is not
>> | implemented for the libi2c driver.
>> | So, I do I specify the offset into the FRAM device???
>> | Thanks,
>> | -Bob
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
