Two network interfaces
    Chris Johns
    chrisj at rtems.org
    Wed Mar 12 00:36:18 UTC 2008
Leon Pollak wrote:
> Hello, all.
> I have the following situation with 2 network interfaces been initialized.
> The first interface is fully functional in HW and SW, but the second
> controller which is connected to the PHY via MII has no physical connection
> to the network and PHY therefore does not have link.
> When I initialize the only first IF and give the application to run -
> everything is OK: I can ping the box without any problem.
> If I only add the second interface to the chain, the first stops functioning -
> no replies to ping and arp and I see the "Still waiting for mbuf cluster"
> message printed periodically.
> I am not able to have the second interface physically connected in some 2-3
> weeks. But I should be ready to work with it when it will be connected.
> Therefore I just wanted to know: if such a behavior may be caused by the
> second "faulty" interface or I need to work hard searching for a bug in the
> driver?
Thomas is correct with the need to correctly size the network buffers. When
getting new hardware up and running I tend to over allocate to remove this
from being a problem.
I see from your trace below the driver is 'rtems_enet_driver_attach' how-ever
there are a few of these in the RTEMS tree so I do not know what hardware you
are using.
I saw from an earlier post mention of the mpc8260ads driver so the remainder
is just guess work. Do you have both controllers in a single device sharing
some resources ? If you do then I would check what is being shared. For
example BD allocation and interrupts are always tricky to sort out.
I hope this helps.
Regards
> Many thanks ahead.
> Leon
> P.S. May be this is helpfull - rtems_bsdnet_ifconfig structures are filled as:
> (gdb) p netdriver_config[0]
> $3 = {name = 0xd5e14 "eth0", attach = 0x56380 <rtems_enet_driver_attach>,
> 	next = 0xf76d8,
> 	ip_address = 0xd5e1c "192.168.50.134",
> 	ip_netmask = 0xd5e6c "255.255.255.0",
> 	hardware_address = 0xd5e7c "00:80:7f:22:61:77",
> 	ignore_broadcast = 0, mtu = 0, rbuf_count = 0, xbuf_count = 0,
> 	port = 0, irno = 0, bpar = 0, drv_ctrl = 0x0}
> (gdb) p netdriver_config[1]
> $4 = {name = 0xd5e40 "eth1", attach = 0x56380 <rtems_enet_driver_attach>,
> 	next = 0xf7710,
> 	ip_address = 0xd5e48 "192.168.1.10",
> 	hardware_address = 0xd5e84 "00:80:7f:22:61:78",
> rtems-users mailing list
> rtems-users at rtems.com
