Need help. when porting RTEMS to L4
Wed Mar 19 14:06:45 UTC 2008
xi yang wrote:
> Hi all:
> I am porting RTEMS on L4 micro kernel . I just
> do it like what UNIX bsp does . But there are
> some problems
> I develop BSP like this
> * cpukit/score/cpu/l4  (Like unix)
> * c/src/lib/libbsp/l4/okl4 (like UNIX/posix)
>  I copy files form unix bsp and change Makefile.am
> and other files .
> * touch okl4.cfg
>   RTEMS_CPU=l4
>   RTMES_CPU_FAMILY=arm
>   RTEMS_CPU_MODEL=pxa255
>   RTEMS_BSP_FAMILY=okl4
The configure infrastructure uses RTEMS_CPU to select
directories at the score/cpu and c/src/lib/libcpu and
c/src/lib/libbsp level.
> * Add score/cpu/l4/Makefile to cpukit/configure.ac
So you accounted for this one.  D
> then ../rtems/configure --enable-rtemsbsp="okl4"
> This cause the toolchain to the host toochain ,
> maybe it can compile some files ,then
Right. This configures the target to be your native machine (e.g. posix
port)
with a BSP that does not exist under libbsp/unix.
> Make
> but It doesn't compile any files , just say
> make all , then ../rtems/configure --target=arm-rtems --enable-rtemsbsp="okl4"
> Make
> It doesnot compile any files, just say make all,
That is looking for okl4 in libbsp/arm.
> What else should I modify the build system to let it compile ?
> anyone can help me ?
Your configure points are confusing me.  You are treating L4 as a
CPU architecture from RTEMS perspective.  What really has to
change?
We have to know the answer to the above question to
know where to distinguish between real hardware and
an L4 version of the same hardware.
My gut feeling is that L4 should be treated as a specific CPU
model within a CPU family because you still want to compile to
ARM but probably have a somewhat perverted view of the
interrupts and maybe the hardware, right?
This would mean you should add okl4 as a BSP and possibly
some ARM-L4 CPU model.  Say it is pxa255 for real, then make
it pxa255l4.  Then you can treat it as a real raw pxa255 when
possible and still ahve the ability to detect it as an L4 virtualized
pxa255 when it makes something different.
It may even be that the same BSP can work with one variant for
real hardware and another for L4 virtualized with a few conditionals
to account for the CPU model differences.  This is done by a few
BSPs including the gen68360, mbx8xx, and motorola_shared.
--joel
> Regards
> rtems-users mailing list
> rtems-users at rtems.com
