RDBMon for ERC32
Teng Chee Wan Philip tcheewan at ntu.edu.sg
Wed Mar 19 20:11:55 UTC 2008
Hi Aitor
Thanks.
Do you need a particular version of the sparc-rtems compiler to compile this?  I also noticed that you need the sparc-rtems-mkprom to make the boot image.  Where can I get that?
regard,
Philip
________________________________
From: Aitor.Viana.Sanchez at esa.int [mailto:Aitor.Viana.Sanchez at esa.int]
Sent: Wed 3/19/2008 10:34 PM
To: Teng Chee Wan Philip
Cc: rtems-users at rtems.com; rtems-users-bounces at rtems.org
Subject: Re: RDBMon for ERC32
hi,
please find attached a ERC32 monitor I developed some time ago. It is not actually the RBDmon but does something similar. I also has a SONIC-T ethernet driver that allows to download the binary or ELF file remotely to the board and debug by means of GDB using the serial line.
The SONIC-T driver may be replaced with the driver in you board. At that time I used the Tharsys VME ERC32 board.
To compile it:
/> make xconfig                        # select the options
/> make
In the image/ directory you will find all the images to be used either on the TSIM simulator or in the real board.
I hope this will help you.
Aitor
"Teng Chee Wan Philip" <tcheewan at ntu.edu.sg>
Sent by: rtems-users-bounces at rtems.org
03/19/2008 01:48 PM
To
<rtems-users at rtems.com>
cc
Subject
RDBMon for ERC32
Does anyone know where I can get a copy of the RDBMon for ERC32 hardware (and can be compiled with the current RTEMS tools)?
The last it was mentioned seems to be at http://www.rtems.org/ml/rtems-users/2001/january/msg00001.html <http://www.rtems.org/ml/rtems-users/2001/january/msg00001.html>  and I don't think the RDBMon is in the RCC compiler system anymore.
regards,
Philip
rtems-users mailing list
http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20080320/c244ff01/attachment-0001.html>
