I want to participate in GSoC from RTEMS
Madhusudan C.S
madhusudancs at gmail.com
Thu Mar 20 04:51:23 UTC 2008
Hi Joel,
First of all thanks a lot for all the support and suggestions. I
am overwhelmed by the response. I am also very sorry for such a late
response. I am going through every mail the moment you post it to the list.
But I wanted to respond once I had a basic knowledge of what you were trying
to tell me. I nearly went through the whole wiki, now I am reading the pdf
that Daron sent me and online docs of 4.99.
All your mails has helped me a lot to understand what is happening down
under. I have understood few things you have explained, though I haven't
understood all. I will ask you as and when I need I haven't understood
inline.
Before that, I wanted to get the RTEMS running to get the taste of how Time
Stamps are working now. So I checked out the CVS HEAD and then installed all
the prebuilt tools from ftp for F8-RTEMS-4.9. Since I have Ubuntu installed
on my PC, I converted those rpms to debs using alien and installed all the
prebuilt tools. When I did bootstrap and configure there were no errors as
such, I did all these for sparc CPU. When I did "make all" it said compiler
cannot create executables, as its given in the wiki I installed libc6-dev
package, since thats the Ubuntu version of libc-dev. But still the make
fails. Can someone help me please. If there is no other go, I will install
F8 through XEN. But somehow I want to get this working on Ubuntu, so in
later stages we can also provide debian packages along with rpms. I can help
you with this, maybe after SoC.
That project in particular requires more knowledge of C and more attention
> to detail than deep algorithmic knowledge.
I have a fair knowledge of C. I hope I have the requirements you have
mentioned above.
Remember the issue is that
> RTEMS used to have all time based upon clock ticks, then we added
> nanosecond
> time granularity and kept the time in structure timespec. It isn't easy
> or
> particularly efficient to do math on struct timespec so this project is
> adding the capability to configure on a per-target basis 64-bit time.
> You do
> have to implement it but since the math will be on the native type
> "unsigned
> long long" instead of int or long, that part isn't rough.
I did not understand what "per-target basis" means here. Can you please
explain?
The rougher side of the effort is in adding a supercore (cpukit/score)
> timestamp handler (e.g. roughly an opaque C "class") and going through
> the supercore and using that instead of struct timespec where appropriate.
I am reading the Documentation of Super Core to understand how the APIs are
structured.
As the Wiki description states, some times need to be native, others have to
> be in API formats. Each case has to be evaluated so the conversions are
> minimized.
Ok I got a rough idea. But I still need to work on it.
Follow the code from one of the clock get time or set time routines down the
> layers to the lowest core methods and you will get a feel. You will see
> routines
> with "convert" in their name or a name like "from XXX" or "to XXX" as
> the names.
> Start at cpukit/rtems/src/clockset.c for one case. There are similar
> routines
> in cpukit/posix/src/clock*.c
> Does that make sense at all?
I went through the code in those files. I also quickly skimmed through the
code I have COed from HEAD and have got a rough idea of how the code is
structured. Now I am feeling somewhat better. But still to get a real feel
of how Timestamps are working now I want to get it compiled and see how they
work. Please help me.
Moreover thanks a lot to both Joel for all the above suggestions and Daron
for that timecounters pdf.
Thanks and regards,
Madhusudan.C.S
With regards,
Madhusudan.C.S
"When liberty is taken away by force it can be restored by force. When it is
relinquished voluntarily by default it can never be recovered"
- Dorothy Thompson
URL: <http://lists.rtems.org/pipermail/users/attachments/20080320/07eabae3/attachment-0001.html>
